Question about Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer
Amana washer model LW6501W2 leaks in front during fill up
My Amana washer leaks in the front as soon as there is enough water in the stainless drum. The hoses all look fine inside and out and are dry all around. I've taken the front panel off and see the water pooling in the front under the motor. Is the white plastic casing under the motor the pump? Could something be leaking inside that? Is it hard to replace? The machine fills fine, spins fine and rinses fine but this leak will not go away by itself. Can anyone assist?
Thank You
Posted by rick121567 on
  • Anonymous May 12, 2009
    the tub is spinning so fast when it starts to drain and spin,that the water splashes over the top...
Anonymous
    Scholar:
  • 98 Answers
It leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Apr 01, 2009
2answers
Why is my amana front loading washer is leaking as soon as i turn it on
If it's leaking immediately it starts to fill check the detergent dispenser isn't clogged up (pull it out and clean warm water and an old toothbrush). Or a pipe to the dispenser may be split, you would need to take off the top panel and observe it filling but beware of high voltages so no touching anything inside with mains connected!!
2helpful
Washer leaks during spin cycle
hi sir, if water leaks during the spin cycle please check the following:
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
  • Test the timer control
mostly water leaks due to the above problems. kindly check them.
kindly rate me.. thank you for using Fixya.
1helpful
Water is leaking out of washer; think it is during the water draining cycle
The AMANA washer has an outer tub and a water pump. Please check these to make sure you can see where the leak is coming from and replace. Also, if your machine has a dispensing system, check all hoses for THAT system. If upon fill up the out tyub HOLDS WATER and DOES NOT Leak, then the outer tub is okay. Carefullky look at the water pump on drain.
1helpful
The amana washing machine model lw6501w2 fills with water and starts agitating and spinning at the same time during the wash cycle. This causes the water to spill over the top and run out the bottom.It...
Sorry that does not sound right,,. there should be interlocks that stop agitating and spinning from happening at the same time. go to the dealer you bought it from and tell them and there may be a recall for your problem and they may replace your machine at no cost or low cost to you no matter how long you have had the machine,at least in theory..
1helpful
Roper washer leaks when filling
It's in the drain hose somewhere,during the fill the water gets as deep in the drain hose as it does in the washer,during the wash the pump runs in reverse keeping the water level in the hose low,during the drain the hose is filled again.
Prop the washer up in front on a couple bricks or boards,start putting in water until it starts to leak and take a peak under the machine.
I need to remove the aggitator to remove the inner basket? maybe?
YOU SHOULD HAVE A SPANNER WRENCH TO REMOVE IT BUT IF YOU HAVE A SMALL MONKEY WRENCH AND ENOUGH MUSCLE YOU CAN REMOVE IT
Amana bottom freezer: water leaking & ice build-up
There should be some kind of drain at bottom of freezer compartment to collect and run off any condensate that collects during defrost cycle.. Clean out the drain and snake out the line that leads from it. Right now the liquid is collecting where it should not and it will leak out the gasket when you have enough of it.
Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer Logo
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Mike
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
