SOURCE: My pc works only when I reset CMOS
Hi, Some of your BIOS settings are not 100% acceptable/compatible with your current setup. I would suggest that you set everything to default, save and close/restart. Another thing you can check is if the Lithium battery needs replacement. Normally it should read 3.0Volts. If the above does not solve your problem, you can consider other things: 1. BIOS update by flashing; 2. Processor to motherboard compatibility - try underclocking your processor by lowering its FSB; and/or 3. Memory to motherboard compatibility - try increasing your latency Good luck and hope this be of some help/idea to you. Post back how things went or should you need further information. kind regards.
SOURCE: Abit AN7 motherboard does not boot - POST code AF
i think thats memory so try removing your ram and re installing it. maby its not pushed in all the way.
Testimonial: "Thanks. And I sold the replacement motherboard that I did not need to buy!"
After 3 years of no issues, the mobo finally give me 7F code. Blank Screen
