Powers up, recieves fine, breaksup on transmit Galaxy 949
Everything else works, but when you key the mic the radio cuts in and out on transmit. just like if you were pushing the mic button in and out. any idea?
As I see it they are the same .The schematic for both radios show the same contact points in the radios so I would assume that the one mic would fit both radios .
You may have a dead meter.
Modulation is audio's affect on swing wattage or pep. Notice that needle moving more with your voice.
Dead key or carrier wattage is without your voice enhancing the power only with mic keyed.
I can only assume that the chipset you are referring to is an ic chip audio or pll which must be working if you are receiving audio.
Check your mic cord................ transmit and modulation and even your receive volume can be affected by the cord/mic plug solder joints or broken wires here.
http://www.cbtricks.com/radios/galaxy/dx33hp2/graphics/dx_33hp2_sch.pdf this is a similar radio the General Lee, Connex 3300hp and Galaxy hp2 share boards i believe dont hold me to that thou.
You probably burnt resistors,relays and transistors near front end sections. Need to take to shop or do yourself. Small solder pencil, solder ******, and change all parts and tiny relay box which may be a black square(but,it rarely fails) I would say transistors,capacitors,resistors. Best to let professionals have a look..Cb shops,Radio Shack, www.copperelectronics.com. Galaxy Radio.Inc.People who service radios; they may charge a good price $$$ though. About $18 to $30/Hr. Labor plus parts.
Hello twelch,
Welcome to FixYa.
My name is John, and I will be assisting you with your issue today.
If it is the old four(4) wire mic, the wiring will be as follows: Pin #1. Shield (Ground) Pin #2. White (Audio) Pin #3. Red (Transmit) Pin #4. Black (Recieve)
If it is a SIX(6) wire! The Blue would go to Pin #1. with the Shield, and the Yellow
has no connection. I hope this was helpful to you. Your Comments and Testimony's are
always welcome here at FixYa. Thanks for choosing FixYa today and in the future.
as far as the transmit frequency changing while you have the mic keyed this is normal, the transmit frequency is a little different than the receive, as far as the lost channels go you need to check the galaxy website and check to see if thier is any fixes listed. if none is listed then you can send the tech's a e-mail and tell them your problem and they will advise you on what to do.
only worked for a few months before it started doing this
