Washing machine will not balance on final spin, tub vibrating terrible, cannot use machine
Hi Sparky,
The reason it's out of balance is because the skate plate shoes are worn out and need to be replaced. You'll have to access the washer in order to do this. There's a video available that shows how to do it.
After you have opened up the washer you'll see that the tub is sitting on a three legged pedestal. The shoes are in between the skate plate and the top of the pedestal. Here's a picture (and part number) to illustrate...
Do one shoe at a time by lifting the skate plate off of the pedestal about an inch or so and wedging it there (I use a hammer handle as a wedge). The shoes simply snap into place, so the old ones will have to be snapped out of place first. Use another hammer and tap the shoes out of their sockets from underneath.
NOTE! ---> When you place the new shoe into its' place DO NOT try to snap it in!!! (if you do, you'll break it) Just let it rest in it's place for now. Remove your wedge and allow the full weight of the tub to sit on it. Then move on to the next shoe and repeat.
After all 3 shoes have been replaced it's time to snap them in completely. Do this from the top of the tub. Using your body weight, press down on the tub from above on all three corners (where the shoes are located). This will apply even pressure to the top of the shoe and keep it from breaking. You should have all 3 snapped in now. Use a flashlight and look underneath to verify (you should see the tabs of the shoes poking all the way through the pedestal).
Now all that's left is to rebuild the washer cabinet and start some laundry!
SG
p.s. I know it sounds like a lot of work, but this job can be done easily within an hour and the parts only cost ~$12.00!
F there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
another cause ------------
The legs on the washer are adjustable, the rear legs are often ( not always ) self adjusting, make sure the legs are not stuck and that they can move freely. But the front legs can screw in and out to move the washer depending on the floor the washer is sitting on. Make sure the washer is as low to the floor as possible. When the legs are screwed out too far the washer becomes wobbly. Often on the metal style legs there are lock nuts that can be tightened to secure the legs so they don't move on you. washers where really meant to sit on a cement floor, if your washer is on a wooden floor look carefully at the strength of the floor. If the floor is moving up and down when the washer is running, the floor may not be strong enough to support the washers weight. Most main floor laundry rooms floors are nailed down, the sub-floor is more secure if the sub-floor has been screwed down. Sometimes extra support may have to be added under the flooring to add some strength
starts to spin but immediately goes out of balance with verl little in there
