Bunn VPR Coffee Maker Logo
Question about Bunn VPR Coffee Maker
After the coffee is made, the water seems to continue to heat
The water gets hotter and steam and condensation builds on the outside of the coffee maker
Posted by conleyce on
  • conleyce Apr 02, 2009
    Where is the thermo switch?
Sulejman Sulejmani
    Novelist:
  • 137 Answers
Check this:
  1. termo swich,
  2. swich for steam
  3. termoswich for steam
replace with new if thay does not work good, and obligatory put one new TERMOFUSE for your safety, becouse she does not trigered obviously.
Posted on Apr 02, 2009
  • Sulejman Sulejmani
    Sulejman Sulejmani Apr 02, 2009
    they 3 together are attached to boiler, each one has his function
1helpful
I have a domena steam press and there is water coming out and soaking the clothes. Water comes out as steam but as well as this it drops out as water.
Lime scale build up inside the elementchambers causing poor heat transfer to the water the steam being cooler thAn usual condenses back into water it reaches the porthole the steam is ejected from and you get this leaking effect steam and water together your need to professionally get the device descaled
Jul 03, 2016 • Irons
Steam coming out of the soap tray,seems to be washing extremely hotter than instructed.
A model number would be useful... But, be that as it may, there are several models that have a thermistor mounted along with the heating element. So, if you have one like that, you can change the heating element assembly and that will probably solve the problem. If not, look around for the thermistor that senses the temperature of the water.
1helpful
2answers
Gaggia Coffee Delux Steam pressure probem
1: do you pres the switch for steam and wait until it is ready? 2: how long time machine needs to be ready for steaming?
solution 1 = if you don't press the steam switch on you will have very small amount of steam. solution 2 = if the machine gets ready only for few seconds to steam, than you must change your steaming thermostat attached in boiler(there are 3 of them: 1 security 2 coffee brewing 3 steam
i hope you fix it soon and enjoy in perfect espresso
3helpful
I've owned this saeco vienne de lux for about 3
Hi
When was the last time you descaled the machine? Scale will build up inside the boiler and insulate the water from the heating elements. The thermostat is on the outside by the heating elements so it gets hot but your water is warm. There are other things but check this first.
2answers
Cuisinart DGB-600BC - water inside the carafe shell
First off, do not submerge the carafe in cold water when it is hot. The water will rush past the seals. This solution involves heating the carafe. Be careful to avoid steam burns
1. Place the carafe on a stove top. 2. Slowly heat the carafe. (make sure you are wearing oven mitts -- avoid steam burns) 3. As the carafe heats the water inside steam will escape the area where the seal allowed the water to get in there in the first place. Steam should appear very quickly, If it does not stop the process right away! Pressure can build up and cause the Carafe to explode! 4. Check the carafe from time to time taking care to avoid steam burns. 5. Once the water has been steamed away, remove the carafe from the stove and allow it to cool slowly. DO NOT place the carafe in water or on a very cold surface until it has cooled. The rapid cooling of the left over steam will cause the carafe to collapse on itself if it is placed in cold water while it is still hot from this procedure.
Cuisinart 12-cup grinder coffemaker all gummed up
It is endemic to this unit - condensation builds up in the grind chute, which makes the grinds stick to the walls of the chute. Decalcifying with vinegar/water helps, but only in an indirect way - by keeping the inside tubing clean, decalcifying generally allows the water to flow through the machine without obstruction. Inside tubing that has calcium, lime deposits built up obstructs water, and makes it flow through the machine slower - when water flows more slowly through the machine, the machine steams off the water at a higher rate, hence more condensation builds up in the grind chute walls.
Generally, i have found all Cuisinart coffee and espresso makers to be high maintenance to a greater or lesser extent, but the Grind-n-Brews have the highest cleaning/maintenance requirement.
2answers
Rancilio epoca - heating element continue to stick on
It's the thermostat for certain.
Te release valve is put there it be sure the tank pressure doesn't get too high such as to cause a steam explosion/rupture of the tank.
Steam generator
hard water build up in steamer tubes a good clean with clr should help remedy this make sure maker is completly cleaned after using clr cleaner
Top Bunn Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Steve
john h
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
