NOT COOLING AND COMPRESSOR TRYS TO START THEN JUST KICK OUT.
FREEZER IS FINE.
You have either a bad compressor relay or a bad compressor. disconect the power and pull the cap off the problem compressor and there will be 2 components that wires are hooked to. leave the wires on them but pull them off. the one with the most wires is the one that you wanna check. shake it in your hand and if it rattles like it has gravel in it then replace it with a new one. that part is your compressor relay. If it doesn't rattle then you have a bad compressor. The other one with one wire is the overload. It is probably white depending on how old it is. Let me know your modle # and I can get you a part #.
Many times a freezer and/or refrigerator do not work right because of
a dirty condenser coil...there are also many other things that can go
wrong.
If
you are hearing a clicking or buzzing then check out the last two
tips.
If your refrigerator is running but warm, then...
Check
out these tips that I wrote about that... it is a great place to
start trouble shooting your unit...and something that you can do
rather then calling a repair person to do a simple thing for
you...
Refrigerator Condenser
Coil Cleaning
Refrigerator Repair
Refrigerator
Troubleshooting
Refrigerator Compressor
Refrigerator
Compressor
Start Capacitor and Start Relay
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
