Question about Nikon D60 Digital Camera with 18-55mm lens
Built-in flash not working
My d60 is only 4 months old. everything else seems to work fine except for the built-in flash. sometimes it fires, sometimes it doesn't. when the camera indicates the need for the flash, it deploys but it doesn't fire, hence, the camera refuses to take the picture. i already took it back to the store where i bought it to have it checked. they said there was no problem. 8 out of 10 times i tried to use the flash, it didn't work. i've tried everything i could think of. i've tinkered with the settings, i even tested it with a newly-charged battery just to see if it just needed a fully-charged battery. it still didn't work. i'd appreciate your help very much. thanks!
  • 2 more comments
  • kikang_ynigu Apr 01, 2009
    the only time i can use the camera is if i do disable the flash. if i set the flash on auto or enable it, the camera won't shoot. and, as i've mentioned, the flash will deploy but won't fire. i've also tried all the flash settings such as auto, slow fire, the one with the red-eye reduction...none of them worked.
  • Anonymous May 11, 2010
    Well, looks like a real fault with the camera, which obviously the service centre doesn't want to accept. I haven't seen such a fault before. Perhaps you need to go to the service centre again.
    Could you have disabled the flash in the settings by any chance whilst tinkering with the settings? If so, I guess there would be some kind of indication on the display that shows a crossed out flash symbol. By the way, I am just guessing and I haven't really used a camera of this model. Just trying to help.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Scholar:
  • Nikon Expert
  • 163 Answers
Please shoot in P mode. In P mode it will use the flash if you pop it up and not use it if it is down.
The flash uses LOTS of battery power. If you battery is weak the flash may take a long time to recycle (charge).
The Flash must be popped up and READY before you can use it. The flash is charged or READY when the RED light is on.
I hope this helps.
Posted on Apr 15, 2017
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 619 Answers
SOURCE: Flash Not firing
Hi , try to flash in dark area and set camera flash on set in all option.if does not fire the flash the flash bulb are busted either the the igniter switch inside was broken.
Posted on May 07, 2008
Anonymous
  • 8 Answers
SOURCE: nikon d40 built in flash not firing but it popped up
there is a sensor in there that tells the camera the flash is up you need to take it to a repair shop its not a at home thing
Posted on Mar 20, 2009
Anonymous
  • 691 Answers
SOURCE: My built in flash won't fire in dark sceneries, it
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Nov 30, 2009
Ty Price
  • 11967 Answers
SOURCE: I bought a new Nikon D3100 last December 26, 2010.
I agree that 6 days is a very short life span for the flash. Your camera is defective and you should take advantage of the warranty since it's probably too late to return it.
Posted on Jan 07, 2011
Canon 430ex ii seems to flicker rapidly sometimes before taking pictures
Yes it is. The system is simply measuring the flash to meter the exposure.
Dec 29, 2013 | Canon Speedlite 430EX TTL Flash
Speedlite 430EXII Flash not working. Batteries OK Everything functioning except that it's not firing. Took 3 pics yesterday and then it stopped working. Regards Alan Paramor
Does it fire when you push the test button (red light)? If so make sure the contacts on the lens and on your camera are clean. My speedlites sometimes don't fire after heavy use and I clean the contacts with a soft cloth and some methylated spirits or isopropyl alcohol. Hope this works for you.
Jan 21, 2011 | Canon Speedlite 430EX TTL Flash
Flash stops working
The flash bulb may be broken. Try contacting Pentax to get it fixed.
Jul 15, 2009 | Pentax Optio T10 Digital Camera
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    Nikon d40 built in flash not firing but it popped up
    Mar 11, 2009 | Nikon D40x Digital Camera
    Sb 600 under exposure.
    You probably haven't changed the camera and/or flash back to TTL mode from wireless mode.  Make sure they are both set to TTL, not commander mode and you should be fine.  Note that the LCD on the flash will indicate which mode it is with a little graphic.  On the D70 you had to switch between TTL and Commander mode to set it up to work using the built in flash as the commander, so you just have to switch back.
    Jan 21, 2008 | Nikon Speedlight SB-600 TTL Flash
    Dishwasher, not working
    which 2 buttons flash?
    Dec 05, 2007 | Dishwashers
    KENMORE GAS DRYER - MYSTERIOUS HEAT PROBLEM
    Most times I replace the coil assy. on gas control valve. OR could be the sensor.Or both.
    Nov 27, 2007 | Kenmore 73952 Gas Dryer
    Nikon D60 Digital Camera with 18-55mm lens Logo
    176 people viewed this question
    Top Nikon Cameras Experts
    Ric Donato
    Ekse
    FIKRET UNALIR
    FIKRET UNALIR
    Level 1 Expert
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
