Question about HP PSC 2210 All-In-One InkJet Printer
Refill hp psc 2210 all in one
I just bought some ink to refill my printer hp psc 2210 all in one, but i cant open it and cant find the cartridge. Its a second hand printer and I dont have user guider or manual. I would really appreciate that if you can tell me where the cartidge is and how to open it?
many thanks
Posted by beryllau on
DROPNDEAL
    Top Expert:
  • HP Master
  • 2,931 Answers
This item uses replaceable ink cartridges (56). You do not refill them.
You can find everything needed here:
HP PSC 2210 All in One Printer series
Posted on Jan 22, 2018
5 Related Answers
Anonymous
SOURCE: HP PSC 2355 Won't accept refilled ink cartridges
If problem is what I think it is (that is if you cleaned whole thing and it is connected proprely), you have only one option. To buy at least three cartridges...problem is due a small trick made by HP. Printer remembers at least two cartridge serial numbers, and then wont accept refilled ones. But if you first stick one, then the other, and on the end the third one(only this one should be really full) it should reset printer and it should foul it to accept it. But on some printers it needs up to five cartridges! What a waste of money :( Anyway, hope this helps...
Posted on Sep 28, 2007
checkitright
CheckitRight
  • 1363 Answers
SOURCE: HP Remove and check cartidge
usually, the error is because it's not recognizing the cartridge. Check the contacts on the printer and clean w/ alcohol. Are you using recycled cartridges or filling it yourself?
Posted on Oct 11, 2007
pherb2000
SOURCE: Refill hp 74 ink cartridge
I found a guide that worked for me:
http://www.alotofthings.com/viartshop/article.php?article_id=491
Good luck! Mike
Posted on Jun 18, 2008
Geraldine Watts
  • 390 Answers
SOURCE: how to refil ink in hp 2120 cartidge
try also resetting the ink levels once ink is flowing out holes. If ink is not blotting from cartridge onto unscented wipe, you may need more ink to let ink get to bottom, to force air bubble out. Half filled ink will create bubbles. Try blowing into ink refil hole also. When ink is free flowing out printer end, you know it is ready to go, and reset cartridges on printer too (ink levels) cheers lilacgerry
Posted on Jul 31, 2008
gbeltrao
Juba Beltrao
  • 10 Answers
SOURCE: Ink Refill for HP Photosmart c7280 not working
Hi Lisa,
If it responds ok with the old cartridge then the problem is with the cartridges' chip not the printer. Probably the manufactor has a problem with certain cartridge chip (contact them!). I would suggest to use the original at the problematic spot if it works without a problem.
- Gilberto
Posted on Jan 05, 2009
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
I refilled my tri-color cartridge at Costco and my printer wouldn't print the alignment page. I bought a new cart and it worked fine. Then I re-installed the refilled cart to verify the fix, and it still...
a refilled cartridge IN NO WAY can lead to printer failure
the ink is the last thing on printer and has no effect to mechanical failures.
check here how you can refill your cartridge
http://www.youtube.com/watch?v=II9gpIXs_lE
Jul 02, 2010 | HP PSC 2210 All-In-One InkJet Printer
I have refilled color ink cartridges for my printer, the printer says there is no ink in them, any ideas?
hi, that is what refill does, the product ink registration that hp generates on new ink registers with the printer but the refill does not. so it will continue to write no ink but it will print normally
Jun 14, 2010 | HP PSC 2210 All-In-One InkJet Printer
How do I refill my HP 94 black ink jet cartridge? I bought a kit but have lost the instructions. When I peeled off the sticker I found five shallow 3 mm diameter holes that seem to have something spongy...
Hi
I have had a look in the manual myself for you but not see any F4 there.
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
Click LINK= http://www.4all2sell.com/pdf/HP-PSC-2210-2210v-2210xi-Manual.pdf
You will need a adobe reader to see this file If you not got an PDF reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 01, 2010 | HP PSC 2210 All-In-One InkJet Printer
My HP psc 2210 is only printing red and yellow on the color test page. Just replaced the cartridges. What do I do?
What I would try doing is remove the cartridges that you just bought. get some isopropyl alcohol and use a cottoen swab to cl;ean around in where the cartidges fit. Sometimes those jets in ther become clogged with old dried out ink and it will not allow the new ink to be distributed.
Aug 10, 2009 | HP PSC 2210 All-In-One InkJet Printer
I changed my black ink and now i get the message left cartridge incorrect..how do i fix it?
HP PSC 2210 InkJet Printer. The following has to be done for checking the Blank Ink Catridge working : 01. Remove the existing Black catridge and Color Catridges from the Printer carefully. 02. Clean the location with a soft cloth with cleaning liquid to make the place dust free. 03. Put the correct black and colour cartridges recommended by HP and that too genuine one. 04. Do not use any refilled or reinked local catridges that will spoil the HP PSC 2210 printer. 05. Re-install the catridges both Black and Colour properly. 06. Take a test print out - both black and colour print outs. 07. Check the Printer status and there is no warning of Cartridges wrongly inserted. Have a Good day.
Jul 14, 2009 | HP PSC 2210 All-In-One InkJet Printer
Dial says to remove cartridges and check. Have replaced cartridge
After cleaning cartridges and replacing refilled black ink, I removed blck ink and replaced with HP 58 photo ink. this aborted the "check cartridges freeze". I still cannot align cartridges after removing #58 and replacing with new HP 57. the operation starts but will not complete.
Any suggestions on how to align cartridges?
dunbarj730
May 02, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hp psc 2210 remove and check catridge DISPLAY MESSAGE. I REFILLED CATRIDGE.
If you refilled your cartridges.]
Make sure they are not overfilled.
Check by removing the cartridge and see that they do not
have a large amount of ink on the printhead area
Dec 20, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
H P psc 2210 printer will not accept ink cartridges have used from this supplier in the past with no problems display reads "remove and check cartridge" this I have done but no cure.
Are you using cartridges that have been refilled? If so I would go buy brand new HP ink cartridges or I would find known working but used cartridges and try again. The ink cartridges on any inkjet type printer are not made to be refilled and if you were to call HP about this problem they would tell you to replace the ink cartridges with new ones and try again.
Nov 10, 2008 | Computers & Internet
Printer Issues
my hp psc 2210 after putting in new cartridge keeps saying press enter to align cartridge. it keeps repeating the same reading.
Apr 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
efs_perpends
efs_perpends
k24674
