SanDisk Sansa e250 MP3 Player Logo
Posted on Aug 31, 2007
Help me plzzz
My sandisk wont delete the bad tracks and it wont connect 2 my computer and every time i try 2 connect 2 my computer it just charges it thats it plz help me!!!!!!
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Aug 31, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
Helped
1687
Points
15
Your usb ports may not be installed correctly, what kind of computer do you have. if it is really old, than you should try getting some new usb ports.
Deleting songs.
Your DB might be corrupt. Folow the delete procedure one more time:
Delete Music Files
1) Connect your Sansa to the computer.
2) Select Open device to view files using Windows Explorer on initial
connection.
3) Select the place where you want to delete music files from
4) Highlight and delete the music file/s or folder from My Computer\Sansa
e200\...\MUSIC
folder. (You can also select from a variety of music
software programs to transfer/synchronize your files).
If that fails, go ahead and update the firmware - it will delete everything, and allow you to start over from scratch among other things.
-Tha Mp3 Doctor
Sansa E270 Blank Screen and Bad Tracks
well if you can still connect it to your computer just format the mp3 this should work after the format just go to WMP and sync your music
Formating:
1. connect mp3 to computer
2. got to "My Computer "
3. find the mp3 in the computer
4. right click on the mp3 drive
5. click on "Format"
6. click on ok
note : formating will delete all picture,songs, and videos on the device
Bad track
To delete songs from your device follow the steps below
You have to make sure that the device is on MSC mode...then make sure your device is plug in to the computer..Then go to programs - accesories - windows explorer, find the SanDisk in my computer, go to media, music and delete them from there.
Either under sync panel in your windows media player it will show your music when it's connected. just click the plus signs for what song you need to get rid of, right click and click delete.
To format it..on your device..go under..menu, setting and there should be a format option option there..let me know if that doenst work for you...
Hope this helps
P.S.Please rate accordingly...
Thank You
Computerrep
Bad track error. songs arent deleting after reformatting and resetting multiple amounts of times.
There are 2 ways to format an mp3 player - if you were formatting the mp3 player from "My Computer," then try reformatting from Windows Media Player instead - I have a "tips and tricks" entry on How to Format an Mp3 Player for details
If that doesn't work, then double-click on My Computer, double-click on the Sansa player, and go to the various folders that it lists - music, voice, etc. Delete the songs ONLY - do not delete the dat, bat, ini, inf, or other system files
1helpful
Sansa bad track
You have to make sure that the device is on MSC mode...then make sure your device is plug in to the computer..Then go to programs - accesories - windows explorer, find the SanDisk in my computer, go to media1.gif, music and delete them from there.
Either under sync pane in windows media player it will show your music when it's connected. just click the plus signs for what song you need to get rid of, right click and click delete.
Hope this helps
If you still not able to delete it let me know so I can have you try something else...
Thank You
Computerrep
2answers
Deleting songs.
Isn't it that you just go to my computer and delete it there?
It says to delete it entirely from it.
Sandisck
My sansa won't connect to the computer now that I have bad tracks on it, I want to delete them to put new ones on, How can I fix this?
Thanks!
Connection/ Transferring tracks problems with Rhapsody.
left it charging over night and all the music erased...
I need Help!!!
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
It wont add songs
Did you already try to format it (go to my computer then right click the device and click format) That should solve the problem
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Alexander
Mohammad Abumuailek
Mohammad Abumuailek
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
