Neither the warning light nor the lamp replace lights are lit. Thanks - Donald.
Reason for fan spinning at high speed after shutdown is to cool down the projector after it has been on
you will feel hot air from exhaust as this is taking the heat away from the lamp, where all the heat is generated
if it shuts down after 20 mins either the projector is blocked, maybe, a fan is not running, filter blocked, or the motherboard is now u/s
Warning Indicator
? When the "LAMP" indicator lights solid red, the projector
will automatically shut itself down.
? When the "TEMP" indicator lights solid red for about 60
seconds, it indicates the projector has been overheated. The
projector will automatically shut itself down.
Under normal conditions, the projector can be switched on
again after it has cooled down. If the problem persists, you
should contact your local dealer or our service center.
? When the "TEMP" indicator lights solid red, it indicates the
fan failed. Please contact your local dealer or our service
center.
Projector keep shutting down say after 5 to 10 min play.
may cause over heating inside,Because exhaust fan spins high speed after its light glow off.
while keeping the hand in front of the exhaust fan ,feeling very hot air.
Please any body you are welcome for any solution for the above symptom
in Epson EMP-50 projector
