Question about Motorola Mobility RAZR V3m Cellular Phone
Razr cell phone got wet, now one number on keypad will not work.
The phone got washed and when it dried out everything works fine but the keypad number 6. What can I do or who fixes these things.
Thanks,
Kelli
Posted by kellisully on
  • Anonymous Apr 12, 2009
    this exact same thing happened to me :/ i dropped it in the hot tub, its number 6 that wont work tooo.
  • kellisully Apr 13, 2009
    thanks and how weird, huh?
Anonymous
    Problem Solver:
  • 12 Answers
Since it got wet, the company cannot fix it. i'm sorry
Posted on Apr 08, 2009
Razr buttons dont work
Hi - I just posted to you, you will need to replace your KeyPad flex cable, this is what is damaged - the cost of the part is about $15 or so, and you will be better to have a professional shop do it for you, if you can't find someone let me know, we do those all day long.
Jan 25, 2008 | Motorola Mobility RAZR V3
My phone screen went blank after dropping in the toilet
You should have left it dry instead of turning it on, you probably have corrosion now, find a local place that works on phones to see if they'd work on it.
If you want to try to completely dry it, put it in rice for 24 hours minimum to draw out all moisture.
Aug 03, 2017 | Motorola Mobility RAZR V3
No display screen
u must let your cellphone dry up b4 u turn it on,1st thing to do dismantle your cellphone case then u can use a hair blower to dry it up. then try to turn it on. if its not working maybe your cellphone suffers a shortcercuit
Dec 18, 2007 | Motorola Mobility RAZR V3
My razor
yes, if your phone gets wet dry it out before turning it on. once dried if still not working properly take to repair shop or replace keypad yourself
Nov 20, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Motorola v3 razor water damage
If a phone gets wet, turn it off, get the strongest rubbing alcohol you can find (we have 91% here) and immerse the phone in the alcohol. Let it sit for a minute or two and then take it out and let it dry. The alcohol will either wash away the water or mix with it to make it dry faster so it shouldn't corrode the contacts. This had to be done with the phone still wet from the original spill. Taking it to the vendor, they will look in the BTTY compartment and see that the phone was wet (little paper sensor that changes color if it ever gets wet) and that voids the warranty so you are kind of stuck sorry.
Nov 19, 2007 | Motorola Mobility RAZR V3
Razr v3xx
it would be best to take the phone to a mobile service center and have them fully service the phone for you.
Nov 08, 2007 | Motorola Mobility RAZR V3
Motorola Razr....wet :-(
if it can't find your network your antena is fryed and you do need a new one if you wanted to you could have somone try to unlock it it might have just lost the coding for your network.
Feb 19, 2007 | Motorola Mobility RAZR V3
Motorola Phone
when you put it next to the light it might have melted part of the circuts in your phone. i have a Mororola RAZR and it got wet, i just put it under a phone for a few days and it dryed out and worked fine. you should try that and if it dosent work you will probally have to buy a new one.
Oct 30, 2006 | Motorola Mobility V220
Motorola Mobility RAZR V3m Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Relax
Relax
Thejus Mt
Thejus Mt
Level 1 Expert
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
