Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
Posted on Aug 31, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error change unable 51
Plug in (screen ({Please wait}}. scanner moves adf moves internal rollers turn print head cycles (screen (about the manual then) CHANGE UNABLE 50 printer will do nothing
  • 5 more comments
  • rel60411 Sep 04, 2007
    it's not connected to computer
    it's used as a stand alone
    it's to be used as a copier and fax.
    i tried with a computer and nothing
    the printer never comes up past the error.
    it has ink tanks that feed tubes to the head.
    Ive taken it apart the waste tank is almost empty
    this unit was working then stopped with this error
  • rel60411 Sep 07, 2007
    the manual Change unable XX
    the machine has a mechanical problem. or
    a foreign object such as a clip or ripped paper is in machine
    thats why i took it apart but found nothing in it.
  • rel60411 Sep 12, 2007
    i gave up an took it to the dump.
    thanks for trying.
  • becky214 Nov 25, 2007
    Was working wonderfully and then got error message "Unable to change. " I shut it down and turned it back on and got a message that black ink was low...then same "Unable to change" message came back on. I changed black ink but nothing helps...just get "unable to change. See user's manual trouble shooting and routine maintenance guide". Any suggestions?
  • rakesh904 Nov 01, 2008
    plug in (screen ({Please wait}}.
    scanner moves
    adf moves
    print head cycles also looked for paper jan couldnt find anything
    please help
Anonymous
Level 3:
Genius:
  • Master 2,985 Answers
  • Posted on Sep 03, 2007
Anonymous
Master
Level 3:
Genius:
Answers
2985
Questions
0
Helped
1027546
Points
5636
Unload the software. Restart the computer come off line. disable the anti virus Re install follow the prompts exactly. If still introuble take a look at www.fixyourownprinter.com
  • 2 more comments
  • Anonymous Sep 04, 2007
    You did not say that in the first instance.
    Never the less if you are able install it on a computer with the software correctly installed and attempt to use it there- We are trying to run a check.
    When using as a stand alone of course the 'printer' will only print something that has been scanned
    i/e being used as a 'copier'
    or to view/print photographs from media cards
    Therefore a more comprehensive explanation of what you are trying/expecting the device to do would be useful.
    We are trying to be helpful here.
    All you have to do is to give full detail- so far you failed to do so.
    this could be a cartridge problem or if the model is so equipped - waste ink tank full.
    An alternatice site to check this out is- www.fixyourownprinter.com
    But please have comprehensive deyail available.
    OK then try your luck with fixyourownprinter there is a section there that deal with brother.
    By the way does the manual - either the paper one or the one the the software disk cover this type of error?
Anonymous
Level 3:
  • Master 832 Answers
  • Posted on Sep 12, 2007
Anonymous
Master
Level 3:
Answers
832
Questions
0
Helped
557746
Points
2204
After power on mfc directly press menu then start mono then 4x arrow-up button. mfc goes to maintenance and beeps permanetly. What error code does the display show up?
  • Anonymous Sep 15, 2007
    This error shows up often after a paper jam. You have to disassemble the printer to see if there are paperpieces left inside the machine. The second job is to adjust the encoder strip at the right place on top of the printhead. Paper sometimes ejects (lift it out of position) the strip. This very simple to do :-)
Error code 51.23
From the HP manual.
51.XX Error, Turn off then on
Description
The product has experienced an internal hardware error.
Recommended action
Turn the product power off, wait at least 30 seconds, and then turn the product power on and wait for it to initialize.
If you are using a surge protector, remove it. Plug the product directly into the wall socket. Turn the product on.
If the message persists contact HP support.
From PrinterTechs.com
51.X PRINTER ERROR
A loss of beam-detect occurred. X description: 1 = Beam-detect error 2 = Laser error
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. 5. Replace the DC controller.
tip
Use this method with your own risk!! E2-2 = No paper (ASF) E3-3 = Paper jam E4 =...
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full for Mp140
turn off printer.
- put your finger and hold on/off with reset/stop button together
- turn on printer power switch
- release on/off button but in the same time still hold stop/reset button and then press on/off button again and hold.
- wait at the moment
- relese stop/reset button 2X.( your will see alarm led blinking for 2X)
- relese on/off button.
wait until your printer digital screen shows number 0.
- after printer panel screen shows number 0.
- press reset button 4x
- press on/off button 1x
wait until your hear printer roller is moving
after your hear roller moving, wait until your dont hear anything from your printer :)
then turn off and turn on your printer again and your will see your printer back to normal.
hopefully this can helped to solve your problems.
Thanks.
please leave your evaluation....
Extra download =====> Fix_ip1000_InkOverflow
on Jul 29, 2010 • Computers & Internet
tip
True guide to reset ink tank absober full on canon mp140
E3-3 = Paper jam
E4 = No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
turn off printer.
Ok world...Good luck
Thanks.
Extra download ====> Fix_IP1000InkOverFlow
Fi-6130z fujitsu scanner jamming repeatedly
Hello Meg,
To troubleshoot your scanner issue, yuo are advised to perform the steps provided below:
1.Remove all documents from the ADF paper chute.
2.Open the ADF while pressing down the ADF open lever. If your has the imprinter option attached, please open the imprinter and then open the ADF.
3.Remove the jammed papers from the ADF.
4.Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, then please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is resolved.
5. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the values, replace Pick roller or Brake roller see if the error is resolved.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Error J1
Hello Sharon,
When a document jam occurs, "J" and "1" will display alternately on the function number display panel of the scanner.Please perform the following:
  1. Remove all documents from the ADF paper chute.
  2. Open the ADF while pressing down the ADF open lever. If you are using fi-6130 with the imprinter option attached, please open the imprinter and then open the ADF.
  3. Remove the jammed papers from the ADF.
  4. Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, please check the followings:
resolved.
5. Replace Pick roller or Brake roller, and see if the error is resolved.Check the consumable counter from the TWAIN driver screen or from the built-in Maintenance mode. When the counter exceeds the values, replace Pick roller or Brake roller.
Thanks & regards,
ScanCare
When i want to print, i have an error 51 23 in the screen of the printer. When i put the power off, after ON, i h ave the same error 51 23 who return
51.23 Error-yellow scanner error
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn the device on.
Laser scanners are not replaceable.
Replace the engine.
2helpful
My printer MFC-240C displayng "Print unable 51"
These errors are usually caused by small (~15mm2) paper scraps being stuck under the print head,
on the maintenance (purge) unit or at the flushing box.
check the left and right end of the carraige area, you may need to turn it on, and plug it quickly, so you can manually move the printhead.
1helpful
How di I reset my Pixma printer MP150 from
E3-3 = Paper jam
E4 = No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
First way
turn off printer.
- relese stop/reset button 2X.( your will see alarm led blingking for 2X)
Second Way
turn off printer.
Good Luck
3helpful
2answers
Install feed rollers in ADF of HP scanjet 5590
You can get a service manual at this website address (HP website):
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Scanjet+Scanner&qry=instruction+manual&submit.x=7&submit.y=4&ctry=emea_africa&lc=en&dlc=en&mode=fb&tmv=0&method=prodFinder&pid=&productBigSeriesOid=&spid=&opname=&pname_desc=&ptype=&stype=&contextual_lname=&spname=&temp_hql=&search=0
1helpful
2answers
Documate 510 scanner ADF problem
Hello.
I am a Support Engineer with Xerox Scanners.
If the feed rollers are worn out beyond the point of cleaning, you will need to have the scanner serviced or replaced.
Please contact us to discuss your service or replacement options by calling 800-648-0410.
Regards,
Xerox Scanners Support
Norman Weimar
Norman Weimar
k24674
