Panasonic Panafax UF-490 Plain Paper Laser Fax Logo
Posted on Aug 31, 2007
Panasonic UF-490 Fax "Power Failure 887"
Problem began when I replaced the empty drum, then paper jam appears on the screen when i began to test it, the roller only feeds 1/8 of the 8"x11" paper leaving a roller mark on paper.Then I thought restarting it would fix the error so I unplugged its power cord. when I plugged it on again, power failure 887 in red screen appeared.
  • Anonymous Feb 27, 2008
    getting error 021 and error
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Jan 30, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
3286
Points
14
Try the all job clear.. press the ff.
FUNCTION 7 Monitor(4 times) then *(asteris or star)
Service mode is appear.. scroll arrow down.. select Ram initialize by pressing set.. then scroll down look for All Job Clear then set..
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 15, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
872
Points
Need password protection to the fax machine
A
Anonymous
Really; i want to thank every body in helping us for maintanance our problems..
Thank you
Eng.Nizar Ghannam
Palestine
Anonymous
Level 1:
  • Contributor 31 Answers
  • Posted on Mar 11, 2008
Anonymous
Contributor
Level 1:
Answers
31
Questions
0
Helped
17776
Points
81
If all job clear did not work with the problem
try this
press the ff.
Service mode is appear.. scroll arrow down..select LBP SERVICE MODE press START
SET LBP PARAM press START
scroll down and select LBP FUSER RESET press start
select YES BY pressing number 1
unplug the unit for 10 mins then plug it again
for more solutions
call us at 02 3633636
PANTRONICS
INTERNATIONAL CORP
FAX # 3637844
Panafax UF-490 fax problem
your lsu unit must be dirty or check your drum unit
tip
Panasonic Fax Machines uf-560 thru uf-990 Drum Shutter Jamming
Remove and discard the drum cover on the bottom of the cartridge, they come unhooked and cause jamming. It's only there for shipping.
Replaced toner but continues to say replace toner&power failure 8
Anthony here. Had a similar problem, fax didn't detect the new toner. The photo sensor does not detect the toner en the fax is new. Put a black tape where the toner slots into the sensor en walla it worked. When the copies become faint I know that the toner is low or over.
A.K (Nairobi, Kenya)
Panasonic UF-490 erroe codes 887 & 054, how to clear?
Your laser unit has failed. It's uneconomical to have it repaired.
Office Fax is telling us to replace drum unt.
Look at the sticker on the machine to get into Maintenance and clear the drum count. I think it's Function 9 set.
instructions should have been in the drum box.
1helpful
Panasonic Panafax U-788 Error Code 021
You may have had a power failure. A technician must reset the fuser memory, or replace the fuser (bad lamp or thermister)
OR just a bad toner cartridge (no kidding) on the uf-788
3answers
Printer Code and Power Failure Error
the machine memory is hung
try this
press Function 7 monitor(4 times) *
service mode is appear
scroll down.. select Ram initialize select all job clear.. if the problem still there.. repeat the procedure but instead of all job clear.. select the Flash memory clear.. found it after all job clear mode
2helpful
2answers
Panasonic PanaFax UF-490 Problem with Drum Unit
for manual setting.. when replacing the drum unit.. press function 7 thend scroll down select maintenance then scroll donw select drum unit then press 2 to clear the usage.then press 1 for yes.
jamming or misfed?
try to check the drum unit you install.see if the drum not installed properly. turn off and on the unit
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
