I have a Samsung ML-3561ND printer which has stopped working.
The paper jams when entering the fuser.
I think the fuser rollers are not rotating and it looks as if the toothed clutch that is supposed to drive them is not engaging.
I would guess that there is a spring missing but that may be nonsense because I can't see where a spring would fit or what the spring would look like.
The problem started when someone decided to print some envelopes. Possibly the gum on the envelopes has caused something to get sticky. That might be just a coincidence.
I've got the same problem with mine. The teeth became disengaged and wouldn't let the motor drive any of the paper handling rollers. I was able to get it working again by simply squeezing the clutch back together to get the teeth to re-engage. I don't know how long that fix will last, and if I have a page jam and have to pull the paper out in a way that causes the rollers to reverse it'll probably disengage again. On the bright side, at least it's easy to pull the fuser assembly out the back :)
Posted on May 28, 2009
Hope this helps, We had a similar problem with a brother colour laser.
If you carefully remove the fuser rollers and toner cartridge grab a moist/damp cloth soaked dishwashing soap, not to wet but and carefully wipe down the fuser rolsers and toner rollers.
Remember toner is toxic so be carefull
Be carefull not to nick the rollers, if anything chips it or scratches it it will mark everything else.
And yes envelopes if fed incorrectly can gum up the rollers.
I have also used metho to carefully clean down all the rollers before just dont use too much.
Another handy tip is follow the path that a sheet of paper travels and watch where it gets caught exactly.
IF you do pull it all apart, Just make sure you take it slow and watch where everything goes to put it all back. Also make sure that you discharge the unit before opening it up so there is no high voltage inside.
Also if you find that the toothed clutch is worn chek out ebay for spares for your model.
Cheers
Hope this helps
Steve
Posted on Apr 01, 2009
May 15, 2014 | Samsung SCX Office Equipment & Supplies
Feb 20, 2013 | HP LaserJet 2300 Printer
Aug 31, 2012 | HP P4014DN Laserjet Printer
Jul 13, 2012 | Dell 3100cn Laser Printer
Jan 09, 2012 | HP LaserJet P3005n Printer
Feb 23, 2011 | Samsung ML 1610 Laser Printer
Jul 07, 2009 | Samsung ML-2510 Laser Printer
Jul 01, 2009 | Samsung ML-3561ND Laser Printer
Dec 19, 2007 | Samsung ML-2150 Laser Printer
May 07, 2007 | Samsung ML-3561ND Laser Printer
Apr 21, 2009 | Samsung ML-3561ND Laser Printer
265 people viewed this question
