Question about Mitsubishi WD-52525 52" Rear Projection HDTV
CAPACITOR 1000 UFD 16V 105C FOR MITSUBISHI WD-52525 52 IN. TV
IS A REPLACEMENT CAPACITOR 680 uFD 16V 105C BETTER THAN 1000 uFD 16V 105C WHAT IS THE DIFFERENCE, AND IS THERE SUCH A CAPACITOR OF 680 uFD 16V 125C THAT RESIST A HIGHER HEAT TEMPERATURE.
Posted by klucero62 on
  • 1 more comment
  • klucero62 Apr 01, 2009
    Hello, I seen a comment by BIG IRISH who said to replace 1000uf 16v 105c with 680uf 16v 105c that is why I asked the question, thank you electech 1.
  • Wilroc May 04, 2014
    The decision to change the capacitor from 1000uF to 68uF is based upon the repairs made by the Mitsubishi Service Center. This change alters the resonance of the power circuit leading to a capacitor failure (a common failure mode on all three boards with the clustered together within the control and input modules of the TV). In a sense, the capacitor is not stronger than a 1000uF capacitor, but this is not the reason Mitsubishi made the change.
    680uF
jason
  • 905 Answers
No you cannot substitute a 680uf 16v 105c in place of a 1000uf
if you want to put a better capacitor in place of the old 1000uf 16v 105c , then use a 1000uf 25v or 35v 105c
the voltage rating will allow the cap to better handle the circuit
Posted on Apr 01, 2009
  • 2 more comments
  • jason Apr 01, 2009
    the difference in capacitance (uf) is the charge/discharge time
  • jason Apr 02, 2009
    no problem , glad to help !
    and thanks for using fixya!
    680uF
The green timer lite is blinking and the tv will not turn on. It's a Mitsubishi Medallion we bought about 5 years ago. It has a 64 " screen from corner to corner. This didn't match any option I was given...
Good Day,
You have a couple of problems.
(LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002).
(LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A
(LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). .
I would not attempt to do this on your own! Call an Autorized Service Center, it wikll cost at least $ 750.
Good Luck, big IRISH.
Dec 08, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I also have a Mitsubishi HDTV 1080, model #WS-55511 and the green power light is blinking wildly. We, also, have used a small wire to reset the set and it isnt working. We have also unplugged the power...
Check C9B01, C9B02, C9B03, C9B13, C9B14, C9B17 and C9B18 (1000 uFD, 16V,
105C) on the DM Power PCB located within the DM Assembly. If they are bad, replace them with
Nov 07, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WD-52525, replaced bulb but still not working
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
Check C8F19, C8F21, C8F22 and C8F27 (1000 uFD, 16V, 105C) on the FMT PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
this is what we at the shop check first. it is quite common. on the power supply board look for swelled up capacitors
Dec 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blinking green timer light and fan turning on randomly, now no power at all
thanks
scott
Sep 30, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Bad caps
Good Day, newgman;
Yes, this is what MIT. says , you might call it a modification.
Aug 24, 2008 | Televison & Video
Mitsubishi wd-52525 dm board capacitor replacement
Good day, husker_shoe;
Good question, but I'm not THE FAMOUS "TECHMAN" but I will try to help anyway. The DM board is normanlly on the left side TV looking from the back. It has a shield around it, remove. The caps are big and black, they look the replacements(only ones on board). Here's what says about this issue:
If the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). (LED does not stop blinking after plug in) On the DM
Good Luck, big IRISH. ps hope this helpful!
PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
It is not an easy job, it will take some time but since you have it apart there is another problem that will accure so might as well do this too:
Tile or block pattern with no video or OSD. Check D8F00 and D8F01 part # 264P828010, also check C8F26 and C8F29 part # 141P148000 (1 uFD, 25 V) on the FMT PCB (part # 930B924002).
All the parts have location numbers like C8F29 that will tell you what and where these parts are.
Good luck, big IRISH. PS; I hope this helpful.
Jul 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Wd52525 capacitor replacement
Good day, krause67;
Jul 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Power supply
Good question, I will try to help anyway. The boards are on the left side TV looking from the back. It has a shield around it, remove. The caps are big and black, they look the replacements(only ones on board). Here's what says about this issue:
PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 uFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
Good luk, big IRISH.
Jul 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi power board pcb post
Good day, steve sc;
Timer light blinking
Nov 11, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
1,700 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
