The control panel for the water and ice is not working. It start by working every other time I went to use it and now it does not work at all. I test the wiring behind the control board and it has 13V. DC. But how can I tell which part is bad, there is the circuit board which cost $90 or the board that has the buttons on it which cost $70. Please let me know what you think.
Your dispensor board , has lost communication to the main control board . You will need to replace the board , which is located behind the refrig , behind the 8 " X 10 " , small panel . The pt # is WR55X10942 . You do NOT need to replace the board on the dispensor . The board behind the refrig , is , easily replaceable .
I am having the same problem and believe you need to replace the circuit board with the one with the buttons. However, I can't find it. GE no longer makes it. Where did you find it?
