Question about Kenmore Washing Machines
Kenmore series 80 washer: does not twist in the middle
Kenmore series 80 washer: the middle that turns has 2 parts, lower and upper. The upper section does not twist at all but the bottom section twists like it should.
Posted by meolareda on
Paulo
  • 188 Answers
Check the agitator by turning it back and forth. It should work like a ratchet (turns one way, locks the other way).If you're able to turn it in both directions, the agitator dogs are worn and need to be replaced.
Remove the agitator cap and the bolt that holds down the agitator. With the bolt out you can remove the top section of the agitator (auger) where you should see 4 small white or beige plastic gears (dogs). Replace those and it should be ok.
kenmore series 80 washer: does not twist in the mi - 12763ce.jpeg
Part number is 80040
Let me know if you need more help.
Posted on Apr 01, 2009
Clothes getting twisted around agitator
That does not sound good. New dogs sound great, but you must get to the bottom of why the clothes are becoming twisted on the agitator. Usually not enough WATER. Think loose flow of clothes submerged.
Long story short, you cannot jam pack this machine. Less clothes, more water, will equal long life.
Be sure that the mating teeth for the dogs, is not damaged. Slipping here would make loud noise.
More water, less clothes.
Apr 04, 2018 | Kenmore Washing Machines
Manfrotto 685B locking problem
I had the same problem with the Manfrotto 685B, and it was due to the grease from the middle section leaking into its locking mechanism. I fixed the problem by: 1. Detach the middle from the bottom section by twisting the metal hub between them counterclockwise. 2. Wipe the grease off from the middle section's locking mechanism, especially from the three gray protrusions. 3. Use a bit of dish detergent to degrease the inside shaft of the bottom section. 4. Dry thoroughly. 5. Reassemble the section back, pressing the monopod release lever to facilitate the insertion. Reclose the metal hub. Ha! Fixed!!1!1!!eleven1!!
Feb 28, 2012 | Manfrotto BOGEN 685B Neotec Deluxe Monopod
Need change battery (LR44) but cant open my HP10S. Yes, I took the 2 screws but I can not open the calculator. Thanks. Klaus
The calculator HP10s has 7 attachments. 4 in sides, 2 in the upper part and one in the lower part. First you need to remove the screws, then you have to push the attachment in the lower part and continue with the ones that are in the sides.
Nov 20, 2010 | HP 10s Scientific Calculator
Kenmore 80 series Model 110.28812790 - water leak inside tub
It's quite possible. First see the Sears parts list for your washer with diagrams of all major parts.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=+110.28812790&pathTaken=partSearch
Then see the Whirlpool / Kenmore Service manual for these washers and check the troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Mar 26, 2010 | Kenmore Washing Machines
Does the fabric softener dispensar come apart?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=7914776481dcf14414831964a8792e18
Depending on the model, your fabric softener may have a ring around its bottom. Push down or pull up the ring and the dispenser should pull straight up. It doesn't twist off.
Also see the following Sears site. It may have an on-line manual for your machine.
http://www.managemyhome.com/
Mar 20, 2010 | Kenmore 22422 Top Load Washer
Series 80 Agitator top dosent work
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
I assume that your model number starts with a 110 instead of 100.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26842692
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Following is an illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
Jan 09, 2010 | Kenmore Washing Machines
The upper portion of the agitator (Kenmore Series 80 top load)stopped spinning as if the thread has stripped. What parts need to be replaced?
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Basic top load, direct drive Whirlpool / Kenmore washers with two piece agitators use "agitator dogs" to allow the top section of the agitator to turn in one direction only.
These are plastic pieces and over time can wear.
See the following for how to replace them.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=71493d5cab3d7784ad8aa7cde8e5e5d4
Nov 17, 2009 | Kenmore 24032\24036 Top Load Washer
My washer will not agitate.
if top load kenmore washer you need to replace the 4 dog ears under the agitater cap,you can get them from your local appliance part store for $2 there called dogs,let me know how you do_mike
Mar 24, 2009 | Kenmore Washing Machines
How do i open my dirt devil kone to empty it?
Grab the upper and lower conic sections, one in each hand. Twist the lower section clockwise to remove from the upper section. The filter is in the section - remove and empty, then replace and twist back to close and lock.
Jan 21, 2009 | Dirt Devil KONE Hand Vacuum MO213BLU...
Kenmore elite washer not agitating properly
pull off fabric softner dispenser ..some twist off others pull blue ring up and then dispenser up..under neath remove the cover by prying cap or pulling up on tabs..remove 7/16 bolt or on some use 1/2 in drive extension to twist out retaning bolt pull top off and replaced the agitator dogs underneath ..part#80040
Sep 14, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
252 people viewed this question
Michael Thomas
Michael Thomas
Harvey Mahal
Tracy
