After changing oil & filter motor idles too fast, then after motor warms up idles goes up to 1500 and then right back down to 1200, back and forth unless the a/c is turned on, then runs smooth, but fast at 1200 rpm. Found NO: Loose or Broken Wires or Hoses. Ran fine before I changed Filter & Oil. Thanks, RIchard at (916) 961-5966
SOURCE: Oil light keeps coming on at an idle
ok. oil ight is probably nothing more than a faulty pressure switch.You can have pressure checked at same screw in port. 15psi is ok...just. very cheap to replace. Ign control module is probably the cut-out fault. You cant really test it; repair by substitution is the trick.
SOURCE: when bought engine idled @ 800 rpm when warm, now
could be numerous reasons. this is your best bet take it in to a mechanic and have your engine codes scanned. it is a minimal charge, some even do it for nothing it only takes 10 minutes.this will point you in the right direction.
SOURCE: 1998 FORD CONTOUR CHECK ENGINE
sounds like EGR valve and sensor this controls idle speed when at a stop. the po171 is a burn lean or rich code need to know what bank 1 or 2. also check for a vacuum leak from one of the hoses.
SOURCE: My 93 Saturn SL2 intermittent stalling issues
I would look at the egr system. First pull the valve and clean it. If you have a vacuum tester this would be a good time to test the valve itself as well. When under load you should be able to see the diaphragm engage and hold and then release as you release the vacuum. If that doesn't work check and/or replace the egr solenoid. It's located on the driver's side of the valve cover and usually runs about 60$.
Yours is a common complaint and the above is the most common remedy. Outside of that you might want to check and clean the idle air control valve and the port where it's housed. If it is extremely dirty or something managed to get stuck in there that could affect you vehicle running at idle as well.
Another thing, even though you just changed the plugs, pull one back out and look at it. If is fouled with oil you might need a new valve cover gasket which if it's leaking badly enough will impede spark.
SOURCE: engine code p0170 changed air filter fuel filter
hello this is a fuel trim malfunction bank sensor 1 meaning O2 sensor is malfunctioning .Oxygen sensor
