Lands Phones Logo
Anonymous Posted on Apr 01, 2009
CRacked LCD display
I banged up my Avaya 4621SW IP LCD disply towhere only the Date in the right top corner displays.
I need a replacement for the LCD.  Does anyone know where to get just the LCD replacement?
Anonymous
Level 1:
  • Contributor 19 Answers
  • Posted on Apr 01, 2009
Anonymous
Contributor
Level 1:
Answers
19
Questions
0
Helped
7886
Points
59
Sorry to say this but I believe the screen can not be replaced.
I recommend calling the company for more information.
Their number is 1-800-242-2121
Testimonial: "I ended up cannibalizing another laptop who's harddrive crashed that had the same size lcd screen. All you have to do is unscrew the case and take out the screen... the plugs are pretty much universal as I found out. The screen went in without a hitch."
How do you change the display names on the Avaya 5420.
hi robert.
see if this helps you,if not go to the link and the bottom.
How to change the display name in Avaya phone? Press the Select soft key or the OK button or the right arrow key. Use the up and down arrow keys to scroll the display to the option Display Name. Press the Change soft key to change the setting or use the left or right arrow keys. Display your extension number and the date and time on the phone when it is idle.
Display Name - Avaya
marketingtools.avaya.com/knowledgebase/user/ipoffice/.../1408/display_name.htm Search for: How to change the display name in Avaya phone?
How do you change the display names on the Avaya 5420 Google Search
Avaya phone 5410 how can I manually change time
The IPO should get its time from the VM Pro server. The time server should be
set to the IP address if the VM Pro pc. If there isnt a vmpro pc, you can set
it manually.
http://mfurrer.dyndns.org/?p=224
For IP Office systems without access to a time server, a number of methods to
manually set the system time exist. These are available in the IP Office 4.1+.
The following method is only supported on these phones: 2410, 2420, 4412, 4424,
4612, 4624, 4610, 4620, 4621, 5410, 5420, 5610, 5620, 5621, 6412, 6424. It is
supported on any analog, T3, T3 IP or wireless (IP DECT, 3600, 3700 Series)
phones.
Note: If the IP Office system that is still configured for automatic time
updates (on by default), any manually set time and date will be overridden on
the next automatic update. The use of automatic updates can be disabled by
setting the System ' System ' Time Server IP Address to 0.0.0.1.
Enabling a User Button for Time and Date
Select the user who can adjust the system time and date.
If necessary create a new user who can be used to log in and set the
time and date before logging out.
On the User ' Telephony tab, ensure that the option System Phone is
selected.
On the User ' Button Programming tab select and double-click on an available
button.
Select Emulation > Self-Administer as the action.
In the Action Data field enter 2.
Enter an appropriate label for the button.
Adding another button set to the Emulation > Time of Day action is
recommended as this will allow the user to view and confirm the systems current
time.
In the User tab, Change System Phone Rights to "Level2"
Send the updated configuration to the IP Office.
Using the Programmable Button
Press the programmed button. If the user has a Login Code enter it as
requested, and press Done
The options Date and Time are displayed.
To set the date press Date.
The current system date is displayed.
Enter the new date, using two digits for day and month. Use the * or #
keys to insert the / separators. The format for date enter matches the locale of
the IP Office system.
During entry the key labeled <<< can be used to backspace.
When the full date has been entered as required, press Next.
Press Done.
The phone will return to idle.
To set the time press Time.
The current system time is displayed.
Enter the new time using 24-hour clock format. Use the * or # keys to
insert the : separator.
When the full time has been entered as required, press Done.
4621 ip phone sitting in discover after resetting and clearing what is causing this problem?
"Discover" is the phones way of saying that it can not see the phone system at the IP address you gave the phone. If the phone is on teh same subnet as the IP Office, check that the IP set in the phone for "CallSrv" is for the IP Office.
If the phone is on a different sub-net, make sure that there is an IP route in the IP Office to allow traffic to come from the sub-net where the phone is set up....
1helpful
How can I tell if my phone was programmed as a deducated line?
What do you mean? A dedicated line ringing to your phone? Or coverage?
What system is this on, as this phone can be used for a wide variety of system.
18helpful
Avaya 8434DX Display won't show date and time as normal display
You should be able to hit the Menu button, then the arrow directly below the TmDay display and then hit exit once the date and time are displayed. The date should disappear but the time should stay.
Sony Ericsson w580i LCD replacement issue
ok. The most probable problem is that the display is loose. heres what u should do. First, slide the phone open and open the top cover of the phone by first removing the top right corner first. Now, carefully remove the display by lifting the bottom of the display first and pulling it out. now, using sticky tape, stick the end of the circuit comin out of the display to the socket in the phone. Be sure to match it properly. now, carefully insert the display back by sliding the top part in and then clickin the bottom into place. Replace the cover and turn the phone on;. If this doesnt work then u hav to dhange ur display.
Avaya 5610 double display on incoming caller ID
Did you get this fixed. I would double check the firmware files of the phone. And maybe reset it.
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
