Question about Jensen VM9510 Car DVD Player
I get no sound from my speakers when i hook my vm9510 everything seems to be hooked up right, its in a 98 nissan sentra, is there a way to fix this?
Posted by j stone on
Anonymous
Radio Work? Try connecting which all should be blue wires together; power/antenna/remote
Posted on Apr 01, 2009
I need a 2000 nissan sentra wiring diagram because my pioneer stereo was hooked up wrongn and now have no dash lights
I can provide the radio wire colors and each function of the wires by color. 2001 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Gray
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
Feb 28, 2018 | Nissan Cars & Trucks
My 1984 nissan sentra wont start it seems like its strving for fuel there is gas flow all the way up to the carb when i hook the line to the carb it doesnt go any ferther the sensor lite comes on on the...
I just replaced fuel pump on my 84 sentra it has auto ac, p.s. parts fell everywhere when I pulled it off...fuel pump is in block next to oil filter..
May 21, 2010 | 1984 Nissan Sentra XE
My sentra car stereo left rear speaker does not work. i pulled the speaker and plugged it into the rear right wire connection and the speaker works fine. does this mean my stereo is going bad ?
No it means the other side has come disconnected or is bumping up against another wire and shorting the speaker out. You need to trace the wire in question and I would hook the speaker back up and take the radio part way out of the dash. Then with the radio on move aroung the wires with your hand behind the radio and see if you hear that speaker coming off and on. If so your close. Just trace it to the problem by continuing to move the wires. If it is not back behind the radio then start at the speaker end and follow that wire with the radio on until you come to either a broken wire or a bare spot in the wire touching metel and fix it accordingly. Let me know how this turns out and please leave me a good thumbs up for trying for you. Raz
Apr 20, 2010 | 2003 Nissan Sentra
Speakers don't work
If you had followed the directions correctly and the old speakers worked as well, take the new radio back for exchange
Jan 18, 2010 | 1990 Nissan Maxima
No sound out of left side speakers, front and back.
easiest way to see if the left outputs have gone is to swap the right and left speakers over. if the left works out of the right channels you know if the set has had it.hope this helps
Apr 22, 2009 | 2004 Nissan Sentra
No audio output from Pioneer VSX-D608 Receiver
If it's under warranty..get a new one.
It's an internal breakdown ...tech service only.
Feb 05, 2009 | Pioneer VSX-D608 Receiver
I dont get any sound
Many vehicles have factory amplifiers that must be activated or bypassed when installing a replacement head unit. If the factory amplifier isn't integrated or bypassed, you won't hear sound from the factory speaker locations. Another possibility is that you have a shorted or pinched speaker wire or terminal. A short at any speaker will shut down the head unit's internal amp, killing the sound to all the speakers. The RCA outputs wouldn't be affected, so the subwoofer keeps playing.
Feb 23, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
128 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Muntejaya Ginting
Muntejaya Ginting
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
