Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
I lose the sound on my 1 year old SHARP aquos Lc-42D62U tv??
My 1 and a half year old Sharp aquos tv loses its sound out of the blue occasionally. This happens at least 4 times a week.
No setting in the audio menu seems to get it back on, even resetting to factory settings. Sometimes it comes back when I unplug & replus the power cord....other times this does not work! Funny thing is there is no sound in the surround home theatre speakers either when it's off on the tv.
It ends up coming come a few minutes to a few hours later, no idea how or why.
I am a lady with next to NO experience with electronics, just logic & can't find any in this case!
Any advice greatly appreciated!
  • 87 Answers
There is a fix for this. Call a Sharp servicer or Sharp electronics the cost of repair is around 200.00 dollars.
Posted on Apr 15, 2009
Sharp aquos settings
My Aquos 47" loses sound occasionally and the fix is turn the TV off via the main switch on the set, leave for 30 seconds and switch it back on, sorted.
Jan 05, 2014 | Televison & Video
Sharp Aquos has distorted colors
The set should be transported upright but that rarely causes these issues-----suspect either main signal board or also possible is the power supply (for voltages changing when set is on).
Also if set was opened look for all plugs to be seated--ones with cloth tape where they connect look at first.
failing that based on age of set consider having a technician look at it or if over 3 years consider a new set with extended warranty--70% of this type of set in our shop (100 plus sets at any time in for repair) are less than 3 years old.
Oct 29, 2012 | Sharp AQUOS LC-42D43U 42" HDTV LCD TV
I have had the LCD 48" aquos tv for over a year.
Seems like a faulty video board. I am so glad you purchased the warranty. They are a very cheap insurance.It should be repaired or replaced by Bestbuy.
Please let me know the outcome!
Jun 06, 2011 | Sharp AQUOS LC-45D40U 45 in. LCD...
Sharp aquos no sound through hdmi
Reset all audio factory setting.Tries unplug,replug it well work,if ur backlight video board it still good.
Dec 17, 2009 | Sharp Aquos LC32D41U 32 in. LCD TV
Sharp Aquos LC C3242U - Intermittant Sound Switching from Mono to Stereo
Not sure if I just got lucky or if the problem is solved..I hooked up my Sharp Aquos LC-32D64U the other night and I had the blue audio box pop up. Mine was only in Mono and would not switch to Stereo...Well, Local cable company is of of Hi-Def boxes but I thought what if my Digital box is bad/old or has some sort of problem. I went down to comcast cable company switched to a different digitial box..came home, hooked it up and so far no blue audio box, plus now it shows that it's in stereo..good luck
Aug 30, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Aquos LC46D64U, problems with av input video signal
You know, I've had two repair instances regarding this particular model line (D64U) where there were problems with only the analog inputs (such as the component/composite).... but with no problem with the HDMI inputs.
Replacing the Main Board fixed these TV's. Since both the Xbox and the Wii present the same problem on two separate inputs, this leads me to believe you most likely have a defective Main Board. If your TV is still under warranty, I suggest calling Sharp to locate your local authorized service center.
Mar 11, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos LC-32D40U-picture goes off at random times
The bad news,your set needs a new inverter board installed.With persistence to sharp,you might be able to get them to pay for the parts.
Jan 10, 2008 | Sharp Aquos LC-32D40U Television
Audio Problems with Sharp Aquos T. V.
Just talked to a fellow at Audiotronics regarding Sharp Aquos.
This is a widespread problem with audio on their TV's, The tech. said there may be a full recall regarding this problem!!!
Nov 10, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
489 people viewed this question
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
