If there are no Auto Zone, Advanced Auto or Pep Boys stores in your area you can order them online in both hard cover and Electronic formats from this website:
you can try this, if it is the original radio. call or visit a dealer and provide proof of ownership. and they will give you code, you can also go to www.radio-codes.com but cost is about 8.00 to get code.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Please
quote ALL the LETTERS+NUMBERS on ANY BARCODES , LABELS or STAMPED IN THE METAL
CASING. There
should be a 14 character Serial Number beginning with RG or RN or PH or similar
(often found stamped in the metal casing ) and maybe a Security Number in the format of
TOA123 or TA123 or just A123 at the end of a barcode so please quote EVERYTHING
you can find
there is no code available for 2000 Cavalier. the radio is programmed to the BCM. you will need a GM tech II to calibrate the radio. If your radio is locked is because of a problem with the car or the radio has been installed from another car.
your car has an anti-theft radio, the code may be hand written in the owners manual if not you need to go to honda to get the radio code. you may need the serial number off the radio.
