Nintendo DS Console Logo
Question about Nintendo DS Console
Connecting Ninentendo DS with Nintendo WiFi USB connector
Trying to connect Ninentendo DS using WiFi USB connector on my PC. Works when I shut off my McAfee firewall but will not work when Firewall is on no matter how low my security level is. The program has full access according to the McAfee program on my computer. Is there something else I must do in the McAfee program to allow access. It works if I only use Windows XP Firewall but I am not sure how secure this is.
Posted by chicken88 on
  • Anonymous Jan 25, 2009
    when i try to connect my ds with my usb then it goes green and then red HELP ME!!!!!!!!!!!!!!!!!!
  • Anonymous Jul 13, 2013
    can you help me
Anonymous
    Novelist:
    Scholar:
  • 114 Answers
The Windows XP Service Pack 2 firewall is actually Norton Personal firewall re-branded with a simplified front end, Microsoft couldn't get they're own firewall to do the job properly (got to love MS quality!). As such he Windows XP Service Pack 2 firewall will offer you as much protection as any other commercial firewall out there. Your Nintendo WiFi USB adapter uses soft AP, in other words it uses a software WiFi Access Point to connect your DS to the web, as well as being able to make a connection to the web it also needs to make a connection between your PC and the DS and you need to think of these as separate networks because that is in-fact what they are. Make sure the second network is allowed in your McAfee firewall, that the Nintendo software is allowed to act as a server and that it is allowed to serve DHCP, in other words that it is allowed to assign IP addresses. The McAfee User Interface is about as friendly, intuitive and helpful as a dead squirrel so this may be a good time to do a bit of reading on ts.mcafeehelp.com
Posted on Aug 31, 2007
Anonymous
Well what u need it afsta.902 it is the security for the action and it is all protectedd it will delete ur conections and u could reboot again tho !
Posted on Feb 01, 2009
Anonymous
Deal with is and turn the fire wall off or just dont us it
Posted on Jan 27, 2009
How can i connect my computer to my nintendo?
https://www.nintendo.co.uk/Support/Nintendo-3DS-2DS/Connecting-to-the-Internet/Connecting-using-a-Nintendo-Wi-Fi-USB-Connector-/Connecting-using-a-Nintendo-Wi-Fi-USB-Connector--243609.html
Error code 054001
The Nintendo DS is unable to connect to an Access Point. What to do will depend on where you are connecting from:
Connecting from a wireless home network:
    • Errors ending in 0 = connection file 1
    • Errors ending in 1 = connection file 2
    • Errors ending in 2 = connection file 3
    • Errors ending in 3 = Nintendo Wi-Fi USB Connector
  • If you have multiple connection files saved to your Nintendo DS, the error message you received can help determine which connection file may be experiencing a problem:
  • Make sure that the DS is within 30 feet of the wireless access point and facing in its general direction.
  • Make sure that any other interfering devices, such as microwaves and cordless phones, are turned off.
If the above information does not work, and you are using the Nintendo Wi-Fi USB Connector, click here for additional assistance.
If the above information does not work, and you are connecting at home with a wireless router, there could be settings on your router that need to be adjusted. Please click here for more information.
Hope this helps...
How can we get wi-fi on our ds lite by usuing a usb cable.
You are thinking of the Nintendo WiFi USB Connector.You can use this to (usually) seamlessly connect your picky Nintendo devices to your router. Once you order/buy it (you may be able to find some at local stores), you simply plug it into your computer and install the drivers required to run it (if any are required). You should then be able to connect using the USB connector.
What does error code:51099 mean
Error Code: 51099
The only access point within range of your Nintendo DS is not configured or is not compatible with the Nintendo Wi-Fi Connection (such as those found in many Hotspots).
Where are you trying to connect from?
1. Wireless Home Router (please scroll down)
2. Nintendo Wi-Fi USB Connector (click here)
3. Hotspot (click here)
Using a router:
1. Please make sure that your router is not on our list of incompatible routers. Click here to view the list and locate your router (if available). If it is listed as "not compatible," then it appears your router will not work with the Nintendo Wi-Fi Connection. Consult the compatibility chart for recommended routers, or consider purchasing a Nintendo Wi-Fi USB Connector. If your router is not listed as being incompatible, please proceed to step #2.
2. Ensure your router has the latest firmware installed. Visit your router manufacturer's website and look for any updated firmware that may be available (these are typically found under "downloads" or by searching for your particular model number). Contact your router manufacturer for additional assistance.
3. Make sure that your network's name (SSID) matches exactly to what you have entered in the Nintendo DS.
1. Log in to your router using the default IP (consult the router?s owner?s manual for assistance).
2. Look for the section for SSID (typically in the "wireless settings" area).
3. After you find the SSID (network name), verify in the Nintendo Wi-Fi Connection Settings of your Nintendo DS that the SSID is appearing exactly as listed in your router. This includes making sure capitalization, spaces, or special characters match exactly.
4. Check Nintendo's router info for special notes, if available, for your router.
1. Click here to go to our Wireless Router Configuration page.
2. Use the drop-down box on the left to select, if available, your router manufacturer.
3. Click on your router's model number, if available.
4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing such things as the Transmission Rate.
5. Your router may not be assigning an IP address to the Nintendo DS. Try manually assigning an IP address to your Nintendo DS.
1. The first thing you'll need to do is find out what IP address your router is using. To do this:
1. Click the "Start" button in the lower left-hand corner of your computer.
2. Click "Run."
3. Type "cmd" into the box and press Enter.
4. Type "IPCONFIG/ALL" and press Enter. The IP address displayed of the PC will be displayed.
The IP address you going to assign to the Nintendo DS must be 10 digits higher than the PC?s. (e.g., 192.168.1.100 becomes 192.168.1.110)
2. You will now need to manually assign this new IP address to your Nintendo DS. For step-by-step instructions on how to do this, please click here.
If you are still unable to connect, please call 1-800-255-3700 in the USA or Canada for more information.
Using a Nintendo Wi-Fi USB Connector:
* Does the Blue Wi-Fi registration tool icon appear in the system tray of your PC (typically this is found in the bottom right-hand corner of your computer screen, near the clock)?
1. Yes. If the connector has been inserted very recently, it may take several moments for it to establish a connection. Retry.
2. Yes. If the USB Connector is inserted directly into the PC, trying attaching the plastic extension cable that came with your USB Connector. Getting some distance between the PC and the USB Connector may help the signal strength.
3. No. Is the software installed? Is the USB connector inserted? Restart the PC, and if it still does not appear, we recommend uninstalling the software and installing the latest version. Click here to get the latest software for the Nintendo Wi-Fi USB Connector.
4. Yes, but it's gray. Is the USB connector inserted? Right-click the registration tool icon and choose to run the registration tool. If it does not respond, restart the PC. If it still does not respond, we recommend uninstalling the software and installing the latest version. Click here to get the latest software for the Nintendo Wi-Fi USB Connector.
4helpful
Trying to connect to internet error code 051112 - 1
Error Code: 051112 The Nintendo DS is unable to connect to an Access Point. What to do will depend on where you are connecting from:
Connecting from a Hotspot
  • Ensure the Hotspot location does not require an internet browser to setup an account, accept a use agreement, or enter a password before accessing their Wi-Fi serice. If the location requires any of these items, you will not be able to connect to the Nintendo WFC.
  • Make sure that the DS is within 30 feet of the wireless access point and facing in its general direction. Signal strength can vary, depending on where the access point's signal is coming from. (Please do not sit or stand in places that will interfere with the location's customers or staff.)
  • Orientate the Nintendo DS so that your body or other objects (such as walls, plants, furniture, and other people) are not blocking the signal. Also, make sure there is no interference from wireless phones (cell phones are okay).
  • If the connection continues to fail, this Hotspot may have their router set up in a manner that is not compatible with the Nintendo WFC.
Connect dsi to the internet
Error Code: 051110 The Nintendo DS is unable to connect to an Access Point. What to do will depend on where you are connecting from:
Ds usb connector
Yes, you have to buy it for around 30 dollars, or, if you have a wireless router, you can use that instead. It'll tell you how to set up the Wifi connection in the instruction booklet that comes with the DS
Wifi connecting
first off you need to either have a wifi connection in you house or by the wifi usb connector and cd rom from nintendo ( about 20 or less if you find it used) I would recommend buying the connector because it is easier to use.
Top Nintendo Video Game Consoles & Games Experts
Aron
Sean Wright
Sean Wright
Alexander
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
