Question about Lexmark X5470 All-In-One InkJet Printer
My lexmark X5470 printer power button does not work.
Posted by donnape on
  • 3 more comments
  • ram1net Apr 01, 2009
    my lexmark X5470 printer power button does not works - any sujest what to do?
  • Anonymous Apr 26, 2009
    I have the same problem
  • ram1net May 01, 2009
    thanks
    but all uou writing her i did it befor i posteded the messege
    evry thing it ok but it still not warking!!!
    i did all what you are writing her and its ok but it still not warking yet!
    thanks
    eli
  • starshine670 Sep 16, 2009
    I have a lexmark X5470 and it has a red light that is on in the machine but the machine it self will not turn on. Got any ideas
Jeethendra K
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 77 Answers
Thank you for contacting Fixya.
Please follow the instructions given below to troubleshoot the power issue:
1. Connect the printer directly to the power outlet. Surge protectors can actually draw power away from the printer. If this fails, please try multiple power outlets to ensure your specific outlet is not damaged, and make sure the printer is not connected to the PC while testing the unit.
2. When trying to power on the printer, feel the power supply box (if there is one) and note whether or not it is warm. If it is warm, the problem is not in your power supply, but most likely in your printer. If it is cold, the power supply might be defective.
3. Ensure you have the correct power supply connected to the printer.
4. If you have access to a voltmeter, please ensure that the power supply is giving out the correct amount of voltage (most of our printers use 30 volts output).
Your's tech support
Jeeth
Posted on May 01, 2009
5 Related Answers
Anonymous
SOURCE: Lexmark X5470 printer
Download the Vista drivers from the Lexmark website. If the printer still doesn't work, uninstall windows Vista and put 2000 or XP.
That will avoid a lot of problems and your PC will run amazingly fast.
Posted on May 05, 2008
fwadley
Farren Wadley
  • 482 Answers
SOURCE: Lexmark x5470 not detecting ink cartridge
If it's not put in just right it will stay on, this has happed to me before and I had to get two ink cartrides be for it worked.
Posted on Jan 05, 2009
s_4u_11
sandip panchal
  • 535 Answers
SOURCE: lexmark printer x5470
remove & reinstall your printer driver & try to print
Posted on Jan 12, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: how do i connect my lexmark x5470 with out cd software
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Posted on Jun 02, 2009
YourZEN
YourZEN
  • 820 Answers
SOURCE: For our Lexmark x5470 All-In-One Printer we are
Overview for Lexmark 5400 series:
http://www.lexmark.com/publications/pdfs/2007/5400/en.html
See set up sheet (page 1):
http://images.lexmark.com/publications/pdfs/2007/5400/setup-sheet-en-es.pdf
Posted on Oct 21, 2009
X5470 constantly is powering on and off
Please try the steps below:
  1. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer.
  2. Disconnect the power cord from the power source. Re-connect after 30 seconds to a different known working power outlet. Bypass any power surge devices or power extensions/strips and directly plug in the cord into the power outlet in the wall.
  3. Re-plug the power supply into the printer.
  4. Press the power button if the printer won't automatically power on.
If the problem continues, please contact Lexmark Technical Support for further assistance. Thanks.
Nov 02, 2011 | Lexmark X5470 All-In-One InkJet Printer
THE TIME IS WRONG ON X5470
To change or set the time on your Lexmark X5470 printer, please follow the steps below:
  1. On your printer operator panel, while on Copy mode, press the Menu button.
  2. Use the left/right arrow button, select Tools.
  3. Use the left/right arrow button, select Device Setup.
  4. Use the left/right arrow button, select Date/Time and configure the time.
I hope this information has been helpful.
Oct 05, 2011 | Lexmark X5470 All-In-One InkJet Printer
My lexmark x5470 does not turn on, and only a red light bright inside near the print injectors. Thank You.
Try to rebrick you printer by pulling out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds. This will reset your printer.
If that doesn't help, try to plug your printer into a different known working power outlet.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 25, 2011 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 powers on and off constantly
I encountered the exact same problem with my Lexmark X5470. After a power failure on Aug 20, the printer would reboot itself every few seconds. I unplugged the power cord and/or adapter for a few minutes and after replugging, it worked fine. However, the problem returns after I power off the printer and then turn it back on, in which case I unplug again for a few minutes. Hope this helps.
Aug 19, 2009 | Lexmark X5470 All-In-One InkJet Printer
My lexmark x5470 will not turn on after disconnect power and reconnecting. Is there something else I can do?
Is the USB cable back in place? Try holding down the #9 button and the select button while you are powering up the unit. If that fails try pressing the select button after powering up the unit. I had a HP all in one 7170 and during a WILD lightning show I got hit through the phoneline. Zap "All Gone!" I called HP support and they gave me these two steps to try, hope one works for you, if not it's time to go shoppin.
Jul 25, 2009 | Lexmark X5470 All-In-One InkJet Printer
I have a lexmark x5470 everytime I try to fax it tries then beeps and say redial but it never goes thru.
Clear NV RAM..... Unplug the Power Supply from the Printer.... Press and Hold the #5 button on the Printer and plug in the Power Supply....... Don Release the #5 button till the Printer turns on completely.... After releasing the #5 button........ Press the Menu button once Keep on Pressing the Right Navigation Key till u find an option saying Maintanence goto maintanenece and go to manufacturing and click on clear NV RAM..... Now as soon as the Printer is Restarted....... U will be able to send and recieve faxes..... Thanku.............
Jan 22, 2009 | Lexmark X5470 All-In-One InkJet Printer
Despite being plugged in and the green LED light on, no display on printer
I have the same model (about a year old) but there are no lights visible on the back of my printer (neither red or green). Have you contacted the Lexmark tech advice website about this problem? They may take a few days to respond but there are numerous possibilities in trying to locate the fault (probably in the power circuitry) and it might have to take it to a repair shop to get it tested (if it is not under warranty).
Sep 09, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470
Aug 13, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
265 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
