Hi i have a wireless mouse on my laptop and the battery went dead so i changed the battery and now i cant seem to get my mouse to move. i tried hitting the reset button on the bottom but that doesnt work
The usb connection and the mouse should have a button both need to be pushed usually the usb connector first then the mouse, or shut down the computer then restart. let me know if this helps.
The USB connection is the item that connects into the USB port it is usually a small squarish device if you do not have that then you are using a bluetooth device not a USB mouse, Infrared is still in use on laptops so there could even be a infra red mouse device running around out there. make sure the batteries are good in your mouse and putting out 1.4 volts at a minimum. new fresh batteries put out about 1.6 volts
This looks to be helpful, but where do I find the usb connection?
