Question about Fellowes Manufacturing FEL36055 Powershred Shredder Bags for Model 380 2 50 Bags and TiesCarton
Won't shred I have a fellowes powershred 380. When the power is on it will go in reverse but does not go forward to feed/shred> I pulled the top off and mechanically it's sound could the power/feed switch itself be bad ? If not that any suggestions. Also when you move the motor forward/feed rotation it moves freely and every thing works jsut no power. Thanks Ed.
Posted by bigedhouk on
  • bigedhouk May 14, 2009
    thankyou ed houk
Edward
  • 105 Answers
You have to replace the main power switch
Posted on May 14, 2009
We have a Fellowes Powershred C0320C shredder which will does not take the material to be shredded except on one end and does not pull it in and shred it.
Try to use the reverse action of the shredder. This runs the shredder blades in reverse and sometime CLEARS the left over shredded material that can cause a malfunction. Careful...watch your fingers as the blades are sharp and they can injure you. Never place your hands or garments near the open blades when it is plugged in.
Check also that the small switch is free and clear of derbies. When the cutting gears are in place on the container box, the small actuator switch is free to turn on or off until the shredding box is full. Once the box is full of shredded material the switch will turn off (a safety provision) and you must empty the container before it will operated again.
Jan 12, 2018 | Fellowes Office Equipment & Supplies
Where is the fuse in the fellowes w11c?
There probably isn't a fuse. Or it's a non-replaceable one.
They suggest you allow it to cool for 20 minutes, when it becomes overheated it's supposed to shut down. Then in the case of a paper jam, try reverse, if that doesn't work, try forward again.
Aug 02, 2016 | Fellowes Powershred W11C Shredder 120V,...
What causes the Fellowes Powershred SB-15C shredder to show that it's full when it isn't?
Check and make sure there is no paper or paper dust covering the Bin Full sensor. underneath the head.
Aug 03, 2014 | Fellowes Office Equipment & Supplies
Needs lubricating
So try lubricating the unit check out this link...
http://www.fixya.com/support/t2659854-shredder_lubricant_sheets
Should cost less that $12 for a package of sheets. Try one and see if the screeching stops.
Good luck..
Jun 27, 2014 | Fellowes Powershred 380 Shredder
All lights turn on as needed and has power but won't grab paper to shred
suspect paper jam try using reverse button the dislodge paper.
suspect paper feed sensor is blocked or damaged there is a light beem in front of the teeth that starts the shredder if this defective the shredder will not start.
suspect a panel or bin is not correctly seated causing the shredder to not start.
Nov 13, 2009 | Fellowes Powershred 320C Shredder
Does not shred red light on
Try soaking the cutter blades with hot soapy water overnight thru the feed slot
Nov 04, 2009 | Fellowes Powershred SB-87Cs Shredder
Shredder motor will run in reverse, but not
Sounds like a bad or dirty switch you can try to clean it with alcohol ( the switch that gets activated by the paper)
-Carl
Jul 06, 2009 | Fellowes Powershred 480 Shredder
Powershred 380-c
Possible door switch or the bag full plate under the machine jamed ot switch bad. Also All shredders need the wheels oiled with shredder oil now and then...
Jun 16, 2008 | Fellowes Powershred 420 Shredder
Fellowes powershred 320
seems to be an issue with the paper feed sensors i suggest you call Fellowes customer service. 1-800-945-4545
Mar 09, 2008 | Fellowes Powershred 420 Shredder
Shredder problems
Seems it could be a problem with one of your sensors Fellowes Customer Service can easily and quickly diagnose your problem. 1-800-945-4545
Dec 07, 2007 | Fellowes Powershred 420 Shredder
Fellowes Manufacturing FEL36055 Powershred Shredder Bags for Model 380 2 50 Bags and TiesCarton Logo
416 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
midnightmove
Level 1 Expert
George Mclaughlin
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
