Microsoft Office Standard for PC Logo
Posted on Aug 30, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Duplicates i have a col of numbers i need to kno if there are duplicates. how?
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Aug 31, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
15190
Points
12
Click in the column - then click the A-Z sorter button on the Standard Toolbar. duplicates will be together.
Anonymous
Level 3:
Master:
Sergeant:
  • Master 461 Answers
  • Posted on Aug 30, 2007
Anonymous
Master
Level 3:
Master:
Sergeant:
Answers
461
Questions
0
Helped
110664
Points
1238
What software are you using? If no then try to use excel. You can list down the # and perform a column check to the #
Ms excel
In Excel Worksheet 2007 the maximum number of rows per worksheet is 1,048,576 and the no. of cols. is 16,384 which is col. XFD, which makes it 17,179,869,184 cells.
1helpful
My easy share software will check for duplicates and then not upload anything because it is recognizing all of the pictures as duplicates. please help!
Your camera is creating new folders and not continuing the number sequence resulting in duplicate numbers on different pictures. You need to use a card reader to download pictures to a folder you create on your desktop. Open the folder and examine the pictures. If you find different pictures but with the same numbers, you will need to manually rename them.
1helpful
I have problem in how to call the matrix using fuction
I don think u are in the right way to program the Matrix in C language, i found a lot of syntax error in your code, but nevermind i had correct it for u. Maybe still need a little correction for your own. Following code:
void matrix(int a[2][2],int b[2][2],int c[2][2]);
main()
int a[2][2]={{3,3},{4,4}};
int b[2][2]={{1,1},{2,2}};
int c[2][2]={0},i,j;
matrix(a,b,c);
printf("product of 2 matrix is");
for(i=0;i<2;i++)
for(j=0;j<2;j++)
printf(" %d",c[i][j]);
printf(" ");
int row,col,sum1=0,sum2=0;
for(col=0;col<2;col++)
row=0;
sum1=(a[row][col]*b[row][col])+(a[row][col]*b[row+1][col]);
c[row][col]=sum1;
sum2=(a[row+1][col]*b[row][col])+(a[row+1][col]*b[row+1][col]);
c[row+1][col]=sum2;
Regarding the value to be know
Yes, you would do a LOOKUP do display the row number.
LOOKUP(H53,A1:G1000,0)
Finding the correct row num
You would have to combine the use of 2 functions. The Address and Match funbctions.
Lets say the number you want the address of is located in cell F1 and you have 2 columns of numbers. One colum in Column A and the other in column B. I will give you 2 formulas. The 1st one will return just the row number. The 2nd one will return the cell address.
Option 1: Lets say you just want to know the row reference of the number in cell F1. Place this formula in cell D1. =MATCH(F1,A1:A20)
If you have another column ytou want the row number of, place the formula in lets say cell D2 and change the column references from 'A' to 'B'.
Option 2: If you want the cell reference, place this formula in cell D1 and D2 instead of the firt formula.
=ADDRESS(MATCH(F1,A1:A20,0),1,1,TRUE)
And just like the first option, for the 2nd column, put the formula in D2 and change the column reference 'A' to 'B'.
Flex Grid
The most common multidimensional array, the two dimensional array table, is best presented to your users in row and column format. The grid control offers a convenient way for you to display table data to your users. The users can navigate the table's values using scrollbars. Therefore, the grid control does not have to be as large as the table, because the grid control automatically displays scrollbars.
To add the flex grid control to your toolbox, select project and components. Add the flex grid control:
lesson97-1.jpg Once it is added, you will see the yellow flex grid control in your toolbox:
lesson97-2.jpg When you place the grid control on your form, you will have to resize it before the control takes on a tabular appearance. As you expand the size of the control, it does not look to much like a table. The problem is that the table's default number of rows and columns are two. To fix this problem, you must configure the rows and columns in the properties window:
lesson97-3.jpg lesson97-4.jpg lesson97-5.jpg The grid control supports fixed rows and columns. These refer to rows and columns in a grid control that do not scroll when the user clicks the scrollbars. The fixed rows and columns provides labels that describe the data. The fixed rows and columns are often called row and column headers.
lesson97-6.jpg When working with the grid control, much code is needed to provide the grid with functionality. Call statements are used to break the code required by the grid control into smaller, more manageable procedures. This is referred to as modular programming (which refers to the practice of placing code with a single purpose in a general subroutine procedure and then calling the code from a second procedure.)
Here is the code for the form load procedure (this example is based on the computer disk example used in the last lesson)
Private Sub Form_Load()
Call SizeCells
Call CenterCells
grdGrid.Row = 0
grdGrid.Col = 1
grdGrid.Text = "Single Sided; Low Density "
grdGrid.Col = 2
grdGrid.Text = "Double Sided; Low Density"
grdGrid.Col = 3
grdGrid.Text = "Singled Sided; High Density"
grdGrid.Col = 4
grdGrid.Text = "Double Sided; High Density"
grdGrid.Row = 1
grdGrid.Col = 0
grdGrid.Text = "3 1/2 inch"
grdGrid.Col = 1
grdGrid.Text = "$2.30"
grdGrid.Col = 2
grdGrid.Text = "$2.75"
grdGrid.Col = 3
grdGrid.Text = "$3.20"
grdGrid.Col = 4
grdGrid.Text = "$3.50"
grdGrid.Row = 2
grdGrid.Col = 0
grdGrid.Text = "5 1/4 inch"
grdGrid.Col = 1
grdGrid.Text = "$1.75"
grdGrid.Col = 2
grdGrid.Text = "$2.10"
grdGrid.Col = 3
grdGrid.Text = "$2.60"
grdGrid.Col = 4
grdGrid.Text = "$2.95"
End Sub
Notice how the form load procedure is used to populate the cells in the grid control. To control cell size and cell alignment, two smaller procedures are created and each procedure is called by the form load procedure.
Private Sub SizeCells()
Dim intColumn As Integer
grdGrid.ColWidth(0) = 1100
For intColumn = 1 To 4
grdGrid.ColWidth(intColumn) = 2200
Next intColumn
End Sub
Private Sub CenterCells()
grdGrid.ColAlignment(intColumn) = flexAlignCenterCenter
Next intColumn
End Sub
Notice that the size and alignment procedures are only applied to columns 1 through 4. Column 0, which is a fixed column reserved for labels, is not formatted using either of the above two procedures.
Here is the final result:
3answers
Vloop
Are you referring to the VLOOKUP function in Microsoft Excel?
I love vlookup!
Suppose you have 1 worksheet with song numbers and titles in Row 1, Cols A:B:
Song# Title
123 Love Me Tender
234 Blue Suede Shoes
345 Dixie
Another worksheet has song number and performer in Row 1, Cols A:B
Song# Performer
123 Elvis Presley
234 Carl Perkins
456 Cher
Notice there is NO performer for song number 345 in the 2nd worksheet.
Now in the 1st work sheet, cell C2 insert this LOOKUP function: =LOOKUP(A2,Sheet2!A:B)
Copy that cell to row 3 and row 4 in Col C. You should get a Performer for all songs even though there is not a song number 345 in the performer worksheet.
Help me out Mr. VLOOKUP.
Insert this VLOOKUP function in cell C2 of the first worksheet: =VLOOKUP(A2,Sheet2!A:B,2,0)
Copy that cell to row 3 and row 4 Col C. You should get the performer names for the 1st 2 songs, but not for 345 Dixie. The result should be #N/A.
That means VLOOKUP could not find a DIRECT match for song 345 in the second worksheet.
That is why I prefer VLOOKUP over LOOKUP.
I have found this explaination of the VLOOKUP parameters helpful:
1. Needle (A2)
2. Haystack (Sheet2!A:B)
3. RELATIVE Col containing result (2)
4. Need DIRECT MATCH ONLY (0)
Hope this helps.
2answers
M.S. Excel , vlookup formulla tell me use
I love vlookup!
Song# Title
123 Love Me Tender
345 Dixie
Song# Performer
123 Elvis Presley
234 Carl Perkins
456 Cher
1. Needle (A2)
Hope this helps.
3answers
About function
I love vlookup! Suppose you have 1 worksheet with song numbers and titles in Row 1, Cols A:B: Song# Title 123 Love Me Tender 234 Blue Suede Shoes 345 Dixie Another worksheet has song number and performer in Row 1, Cols A:B Song# Performer 123 Elvis Presley 234 Carl Perkins 456 Cher Notice there is NO performer for song number 345 in the 2nd worksheet. Now in the 1st work sheet, cell C2 insert this LOOKUP function: =LOOKUP(A2,Sheet2!A:B) Copy that cell to row 3 and row 4 in Col C. You should get a Performer for all songs even though there is not a song number 345 in the performer worksheet. Help me out Mr. VLOOKUP. Insert this VLOOKUP function in cell C2 of the first worksheet: =VLOOKUP(A2,Sheet2!A:B,2,0) Copy that cell to row 3 and row 4 Col C. You should get the performer names for the 1st 2 songs, but not for 345 Dixie. The result should be #N/A. That means VLOOKUP could not find a DIRECT match for song 345 in the second worksheet. That is why I prefer VLOOKUP over LOOKUP. I have found this explaination of the VLOOKUP parameters helpful: 1. Needle (A2) 2. Haystack (Sheet2!A:B) 3. RELATIVE Col containing result (2) 4. Need DIRECT MATCH ONLY (0) Hope this helps. Let me know if you have any questions.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
