HP LaserJet 1020 Printer Logo
Posted on Mar 31, 2009
Double images once i send a job to the printer, the images come out double. what could the problem be.
A
Anonymous
A little late responding, but is most likely a defective toner cartridge
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 17, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
591
Points
Once i send a job to the printer, the images come out double
kindly help me to solve the problem
nisha
I have to reset my datamax i4208 every time I print. I cannot do more than one print job at a time. Help.
I need more information. What system are you using to drive the printer with? If it is a Windows computer it is almost certain to be a faulty/outdated driver.
Double sided copies
Your printer has Duplex printing Capabilities. However when you are ready to send the print job, open the Printer Properties and select Double Sided.
To copy a Double sided document, insert it in the ADF (Automatic Document Feeder) and open the copy settings on the machine and select Double sided.
My canon irc 5185 double image in black images. any advice
Print Black images with any color piece (ex. page with black text and one red letter in up-right corner) 40-50 pages in one job.
Are you see a double black image?
No: Fuser trouble on high-speed.
Yes: Replace the Drum Unit (Black).
It says it's ofline
Once you have added either a USB or networked printer to your PC or Mac computer, you can begin sending documents to print. However, on occasion, a print command will create an error on the printer and take it offline, which will prevent all future jobs from printing. To resolve this issue, you will need to change your printer settings from offline to online.PC Instructions
Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
Towards right hand side of printout, characters ap...
If you are getting a "shadow" behind the text or image it is probably your fuser that is causing the problem. Anytime you see a double image or the print is smearing the fuser (aka fixing assembly) is to blame. You can troubleshoot the problem to see for sure before calling out a technician. Send a one page test print job to the printer. Open the rear "output" tray so that the print job exits the rear of the printer. Watch the paper as it is pulled into the machine. When you see the leading edge of the print exiting the printer open up the front door of the printer. This will of course cause the machine to jam up but its worth it. Carefully remove the toner cartridge. Look at the print on the page still inside the machine. Do you see the same grey image? If not then the problem is the fuser. If you do see the grey image then the problem is the toner cartridge. Stopping the print job in the middle of the printer like that allows you to see what the image looks like before it goes into the fuser. If the fuser is the problem call a tech. It is about a $100 - 150 repair for the fuser depending on the labor rates where you live.
4helpful
2answers
Sent too many labels to printer - need to reset
As the previous expert has stated, with the printer paused, press the cancel key to cancel the job. One thing to note, is depending on how your software sends the print jobs, you may say print 1000 labels, but the software sends it one at a time, so basically you have 1000 print jobs in the printer. If you pause the printer, press and hold the cancel key. Hold it for about 2 mins. This should clear the buffer.
Double image is printed on one page, overlapped on Brother 7225
It sounds like a piece of paper is wrapped around the fuser roller. Look in the rear of the machine with a flashlight.
1helpful
2answers
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
CANCELLING A PRINT JOB WITH THE PROGRESS METER:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
If no PROGRESS METER appears, you can access the document queue in this fashion:
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Workcentre c2424 Color Problem
For Microsoft Windows 2000 / XP OS:
  1. Within an application, click on [File] on the toolbar, and then select [Print] from the menu. The Print window will be displayed.
  2. Click on the [Properties] button. The Properties window will be displayed.
  3. Click on the [TekColor] tab.
  4. Select a TekColor correction.
    NOTE: It may be necessary to try all the color corrections to obtain the required results.
  5. Click [OK] twice to send the print job to the printer.
For Microsoft Windows 98 / ME OS:
  5. Click on [Apply].
  6. Click [OK] twice to send the print job to the printer.
From the Apple Macintosh OS 9:
  2. From the General pull-down menu, select [TekColor].
  3. Select a TekColor correction.
  4. Click on [Print] to send the print job to the printer.
From the Apple Macintosh OS X (10.2.x and 10.3.x):
  2. From the Copies and Pagespull-down menu, select [Image Quality].
    NOTE: If the Image Quality option is not displayed on Copies and Pages pull-down menu for OS X, configure the printer with the correct PPD. See the procedure below, if needed.
To configure the Printer with the correct PPD:
The PPD file contains features a particular printer supports such as TekColor Corrections. In order for the TekColor Corrections and other printer specific features to be available, the correct PPD file must be specified when the printer is installed, or modify the setting following the procedure below.
  1. Open the appropriate utility: Print Center (for OS 10.2.2.x) or the Printer Setup Utility (for OS 10.3.x):
    1. Double-click on the [Hard Drive].
    2. Double-click on the [Applications] folder.
    3. Double-click on the [Utilities] folder.
    4. Double-click on [Print Center] or [Printer Setup Utility].
  2. Select the appropriate printer from the Printer list.
  3. Click on [Printers] on the toolbar, and then select [Show Info] from the menu.
  4. From the Name and Location pull-down menu, select [Printer Model]. The current PPD being used will be displayed.
  5. If the PPD displayed is incorrect (for example; the PPD is set to 'Generic PostScript Printer'), click on the pull-down menu, and select [Xerox].
  6. Select the corresponding PPD for the printer and then click on [Apply Changes].
    NOTE: Make sure the correct feature set is selected. For example; if the printer is a Phaser 8400DP, make sure the DP feature set is selected.
  7. Close any open windows.
  8. Make sure the Image Quality option is available on the Copies and Pages pull-down menu following the OS X procedure above.
Printing the same picture all the time?whats wrong
go to priner and faxs in control panel double click "hpdeskjet" driver icon, window should open with pending jobs, you can delete them before they get to printer, if jobs are at printer then power off and on of printer will clear its memory of jobs requested
maybe too one of your pictures is bigger than the paper so your printer is trying to finish very big job. either way powering off printer and deleteing jobs in driver then power on printer will enable next job to be sent
k24674
Grand Canyon Tech
Grand Canyon Tech
