Question about JVC Televison & Video
48'' Rear projection picture fading
I bought the JVC 48'' rear projection HDTV in Aug 2006. There is been a blue blob on the screen for months that I have ignored. The picture faded out and went white but the sound stayed on. I went through the menu and did an automatice convergence. Now there is a faded picture, yellow and red border and what image I can see (faint) also has a ghost.
Posted by ghauck on
  • ghauck Mar 31, 2009
    my tv does not have color wheel...has bulbs
Nate Stansfield
  • 11,896 Answers
Sounds like your color wheel is fading.
Posted on Mar 31, 2009
  • Nate Stansfield
    Nate Stansfield Mar 31, 2009
    How bright is your bulb? If your tv still shows a picture, you bulb or ballast may be fading. The bult shines light through a color wheel which is projected on to the tv screen
My jvc rear projection 48" tv is showing double images, what can I do to fix this problem
In the menu do the auto convergence. If still bad replace the convergence ics. Also check resistors around the ics. You can remove the front grill and access the conv board from the front. Small board on the right. It popps out.
Mar 25, 2010 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP74 BLUE CONVERGENCE ADJUSTMENT PROBLEM
Make sure you bought genuine Sanyo chips...if not goto www.TvRepairKits.com and get theirs.
Aug 05, 2009 | JVC AV-48WP74 48" Rear Projection...
Sony blue screen
May need new globe This can only be rectified by a service engineer. Any Sony TV Outlet (sales) should be able to advise you on the cost of fixing this problem.Be porepared for a shock at the cost though
Jul 27, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
JVC AV-48WP74 48 in
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 24, 2008 | JVC AV-48WP74 48" Rear Projection...
Jvc av-48wp74 48 in.rear
Jan 18, 2008 | JVC AV-48WP74 48" Rear Projection...
Blue screen
convergence ic and resistors require replacement and that you need to check for cracked solder.
Dec 28, 2007 | JVC AV-56WP74 56" Rear Projection...
Colour problem in jvc
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 13, 2007 | JVC AV-48WP74 48" Rear Projection...
Turns itself off after about 10 minutes of watching, then Blue Power Button Light starts blinking. Unplug and replug and then it will turn itself off again. Please Help my JVC AV-48P575 48 in. Rear...
I have experienced that and I found out that it was plugged to 110 volts instead of 220 volts. Becaouse I bought mine in the Philippines,it is 220 volts.
Nov 05, 2007 | JVC AV-48P575 48" Rear Projection...
Televison & Video Logo
244 people viewed this question
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
