Question about Dell POWEREDGE 1950 Server
Setup can not find any hard disk while installing win 2003
I am installing win 2003 on DELL PowerEdge 1950 server that is currently running unix and during the course of installation, setup can't find any hard disk. Please help
Posted by innoruz on
  • Blue Sky IT Strategies
    Blue Sky IT Strategies May 11, 2010
    Does this server have hardware RAID? RAID Controller? You may need to setup the RAID stuff first. Dell often has manufacturer cds with all install wizards to follow including RAID setup. Are you using CDs that came with the server?
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    which OS u are trying to install and what abt ur hard drive is it SATA or IDE pls let me know
Anonymous
  • 4 Answers
During setup you must specify any raid drivers that are required. Have the raid controller driver on floppy and insert when prompted.
Posted on Apr 23, 2009
  • PRASHAN May 23, 2013
    i dont have a floopy drive....
Hard disk drive not detected during installing windows server 2003
It depends on what type of drive you are using. Plus, you may have to specify the array controller drivers if your are using the SAS (Serial Attached SCSI) drives.
May 22, 2013 | Dell POWEREDGE R610 (4640223) Server
Setup did not find hard disk
If there is no Raid card then you have to change the setting of SATA controller Native mode to IDE or Compatible mode
Apr 09, 2012 | Dell POWEREDGE 1950 Server
I want to install windos 2003 server on dell poweredge 2600 but the server is very slow i want help
I am not sure what you mean by "slow" so I will anwer in general terms. I would recommend 1st that you make sure the PowerEdge meets the recommended hardware specs for Windows Swerver 2003. (Memory, CPU speed, Hard drive capacity, etc.) 2nd- I would run two Xeon processors instead of one and add as much memory as you can put in your system.
I run MS Server 2003 on one of my servers and here is the configuration that I am using:
2 Xeon 2.8GHz processors
6GB ECC Memory
120GB hard drive for the server operating system (Nothing else is on this drive)
750GB hard drive for all other applications
External NAS storage for files, data, etc. (connected to my netword via Ethernet 5e)
With this setup, my server has been running very well for 6 years now. I do maintanance every week on it to keep it up to par. (Simple dusting, checking cables, etc.)
Good Luck.
C2Solutions
Sep 11, 2011 | Dell PowerEdge 2600 Server
Can't install Win Server 2008 on Acer Altos G320, it keeps asking for a driver. The Server currently has a HW RAID setup with two SATA disks and is running Win 2003.
you need to get the drivers foryour hard drives
and when u get to the hard drive bit of the setup click install third party raid drivers
or install hard drive drivers
good look ;)
Dec 23, 2010 | Acer Altos G320 Server
Poweredge 1800 server
Hey,
I looked over the spesifications for the poweredge 1800 servers, go ahead, it will work perfectly but there is one problem in the windows XP setup, you will need to insert / load SCSI or SATA drivers for the hard drive With a floppy disk, or if you don't have a floppy drive your going to need to create a custom windows xp setup cd and add the drivers into it so it can start the SCSI or SATA hard drive and finish the install. without the drivers it might not find the hard drive.
Aside from that I don't see any other problems. You should be able to get the drivers, and everything ese from dell site
http://support.dell.com/support/downloads/
Actually I looked over the dell downloads, I see only windows 2000 on the list with windows server 2003, and 2008 and linux distributions.
This could be a 2nd problem, drivers might not be avaialble, or work with xp, but we might be able to get it to work.
So two problems, SCSI or SATA drivers in windows xp / windows 2000 setup
2nd problem is in windows xp drivers, you could try windows 2003's drivers and 2000's and see if they work, if not, then we would have to look for drivers ourselfs from the internet.
So xp might cause headache but we might get it working, windows 2000 seems to be supported perfectly.
Let me know how the project goes
Thanks,
Ekse
Jun 03, 2009 | Dell PowerEdge 1800 Server
Installation problem
You have to have raid drivers on a floppy,
I know with xp it asks you to press F6 for third party driver during installation...
Mar 31, 2009 | Dell POWEREDGE 1950 Server
Valid operating systems fro Power Edge 1800
During the Windows XP setup you will need to provide the RAID driver using a pre-formated floppy disk.
Windows will ask you if you want to provide additional drivers and give you the key combination to use to do that.
Jan 21, 2009 | Dell PowerEdge 1800 Server
CAN YOU TELL ME HOW TO GET WINDOWS XP TO LOAD ON THE DELL 2600 POWEREDGE SERVER IT ONLY OFFERS SERVER 2000 AND SERVER 2003 AND I CANT USE EITHER OF THEM THANKS MIKE
Hi tham01,
First off, if the server has raid already setup, you will need to go into lsi logic to format the drives so you can install XP. Once the drives have been initiated from the server bios, just place XP in the CDROM, and shouldn't have a problem loading on the 2600 POWEREDGE SERVER. If your trying to install it with the Dell quick install disk, you can't!!! Install it on it's own without the Dell Disk.
Good Luck!
Mark
Jan 13, 2009 | Computers & Internet
Dell POWEREDGE 1950  Server Logo
1,981 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
