Pontiac 2000 grand am wouldn't start anymore cant hear fuel pump it has 2 security systems manufacture and after market. Was told they were disabled, they weren't. So now my lights flash my trunk has opened doors lock the key wont open the doors only after I try few times. After market was disconnected. They car tried to start but didn't hear fuel pump lights stopped flashing. Tried to turn car over again wouldn't start and lights are flashlight again doors lock again! Ive been without my car for almost 3 months I Pd someone to fix it haven't seen them again for over 3 wis. Can someone please help me figure this out or is car lost cause. I'm hair dresser & need my car Please help me???
First most GM OEM systems will need to recognize the key first and foremost ,to do that you will need to roll window down on driver door,turn the key to the run position and with engine NOT running leave the key on for 10 minutes exactly ..then turn ignition off then try to start engine. if original system is working engine should start normally
SOURCE: 1999 jeep grand cherokee / 4.0 L.
I had a skim module go out in mine in the ignition, and I have a 2001. It's a 100 part, and now it starts fine.
SOURCE: need to bypass triad security system - car wont start
There are several configurations of the same security system. But one sure fire way to correct this issue is to get a bypass kit. Any shop that installs remote startups has the ability to bypass this system. Since the sytem measures the resitance of the key/lock and asociated wiring any shorting of those wires will make it very difficult to defaet without some expertise.
Sometimes the remote atart kit also includes the bypass, so you can get two for one here.
Good luck
-FW
SOURCE: 1997 ES 300 How to reset anti-theft system when car won't start
With the doors shut, insert the key into the drivers door lock. Lock and unlock the door 5 times. This should reset the system. If that doesn't work you should contact a qualified repair shop.
SOURCE: 94 Jeep Grand Cherokee diagram panel flashes on
there are two buttons on the diagram panel screen, push and hold top button and a one of the entries will start to blink, then you use the bottom button to change the entry, when you are ready to move to the next entry push the top button again.
SOURCE: 2000 Pontiac Grand Am -- Security light/Passlock
there is a way to bypass the system we do it often but you will need to buy a data bypass unit to install in order to bypass the passlock sensor in the dash. Once the unit is installed, it is turned on by inserting the key into ignition, then the unit will send the proper code to the BCM allowing it to unlock the ECM and then car will start.
