Question about Vivitar ViviCam 3765 Digital Camera
AC adapter for ViviCam 3765.
I want to use an AC adapter for my Vivicam 3765, I have one which is not a Vivitar.
It is a: Class 2 transformer.
Input: AC 120V 4W
Output: DC 3V 400mA
Polarity: Shield (-) , Core (+)
I need to make sure that the ratings and polarity are correct before attemting to try it on my camera.
Thanks a million
Roger
Posted by roger10850 on
Anonymous
The polarity is correct, but 400mA is not enough. One commercial supply I saw was rated at 2.5A. I even suspect 3v isn't enough as I have tried an external battery pack with D-Cells in it and after a few flash shots it wants new batteries. The camera itself seems to be over-sensitive to "low" voltage and complains about new or freshly charged batteries (see other posts).
There is a problem with these cameras in this battery voltage area. I have asked Vivitar what external voltage to use, but no reply. Good luck! I am sufficiently fed up with this camera that I may try 4.5v external supply and if it blows up, good riddance!
Posted on Jun 19, 2009
I have a Vivitar Vivicam 6320. There was an AC adaptor but that has been mislaid. I would like to use a generic adaptor. Any help would be appreciated.
There are universal adapters that have several common voltages with a selector switch. They come with different style interchangeable plug ends, so one of them will fit your camera.
Original Power Powerline 1300 mA Universal AC Adapter One similar to this will work well for you.
Dec 06, 2016 | Vivitar ViviCam 6320 Digital Camera
Does anyone know how i can use my 3765 for a webcam i'm desperite i called vivitar and got the runaround. please help
You can't. The 3765 was designed as a camera, storing high-resolution images (and videos) to a memory card. It was not designed to stream live video to another device.
Jul 11, 2010 | Vivitar ViviCam 3765 Digital Camera
No installation cd-rom for Vivitar Vivicam 3765!!!
The best I can do for you is give you the number for vivitar support. I have looked to see if I could find the installation files and no luck. I am pretty sure that Vivitar can help you. Best wishes.
Customer Support [email protected] US: 1-800-592-9541 UK: 0-800-917-4831
Sep 17, 2009 | Vivitar ViviCam 3765 Digital Camera
I found a plastic top which fits and acts as a lens cap.
Jul 14, 2008 | Vivitar ViviCam 35 Digital Camera
AC Adapter
Where can I get a replacement charger for my Vivitar Vivicam 5105s digital camera.
Dec 31, 2007 | Vivitar Vivicam 5105s Digital Camera
No software for vivicam 3765
You don't need any software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Dec 24, 2007 | Vivitar ViviCam 3765 Digital Camera
Vivitar ViviCam 3765 Digital Camera Logo
124 people viewed this question
Top Vivitar Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
