Question about Panasonic PT-51G53 51" Rear Projection Television
Panasonic PT-51g53W Dark Picture
I have read that some Panasonic TV's (PT-51G44A) have a dark picture due to a single cap. Does that apply to this set as well? Chassis id AMLEDP811. 3 CRT's. If I use my DVD player and set the DVD player to bright, I get a pretty good picture. Is there such a thing as a video amplifier?
Thanks,
Tom
Posted by tinker596 on
5 Related Answers
Anonymous
SOURCE: PICTURE DARK
Where is the chip located? Where is the disc capacitor? I have no service manual is there picture of parts somewhere to locate these?
Posted on Apr 05, 2006
Anonymous
  • 337 Answers
SOURCE: dark picture
I think you have a regulation problem and all the voltage supplies are lower than what they should be,the fact that the picture gets distorted is one thing it lead me to believe that is the problem.This can be caused by a loose conection in the power supply ,I would suggest not to use it until it gets repaired or it might become worst and more expensive.Be careful if you remove the back and try to repair it yourself.
Posted on Oct 02, 2006
Anonymous
  • 398 Answers
SOURCE: panasonic pt-51g53w
Usually, in the Panasonic projection sets that start but then shut right back off, one of the convergence IC's has shorted out and is drawing too much current. When the TV is turned on, the computer senses the extra current and shuts the set back off. The set should be serviced by a qualified tech familiar with Pansaonic projection sets.
Posted on Aug 28, 2007
Anonymous
  • 398 Answers
Usually, when a Panasonic projection powers up for a few seconds and then shuts down, it is because one of the convergence IC's is shorted and drawing too much current. This is usually very easy to troubleshoot because the shorted IC causes one of the large reisitors near it to glow red hot just before the set shuts down. The set should be serviced by a qualified tech familiar with Panasonic projection sets.
Posted on Sep 02, 2007
Anonymous
  • 8 Answers
SOURCE: my picture is dark and have changed the brightness
This model is notorious for needing a new lamp about every 2 years. The lamp is accessed through the front by removing the long plastic cover under the screen (it just pulls off). Under that, to the left of center, is a square cover with one grey plastic screw. Loosen the screw and pull the lamp assembly out. It should just slide right out. Turn it around and look at the lamp. If the lamp face or reflector looks "cloudy" or "misty". Replace the lamp with Philips part number TY-LA1000. Just Google the number and you will find them available for around $100
Posted on Mar 18, 2009
Dark picture
Please check your TV's Picture mode setting. Use the VIVID picture mode to achieve the brightness video.
Mar 11, 2014 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic 51 inch rear projection--bought in 98 has dark picture
http://www.purelandsupply.com/Panasonic-Projector-Lamp.html or go here and call them @ https://www.interlight.biz/ they will answer any question and are half the price most of the time, please give me high rating
Apr 16, 2010 | Panasonic CT-27SL14 27" TV
Chage bulb tv is still dark
The wrong or faulty lamp may cause darkness
Apr 21, 2009 | Panasonic PT-52LCX66 Projection Television
Picture quality on PT-50LC14
clean out the housing (where the lamp is) the go through your menu and check the tv settings ie...color temp, picture, contrast, ect...try resetting it back to the default and go from there
Nov 09, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Dark picture
do you get all three colors? red, blue and green?
Dec 16, 2007 | Panasonic PT-51G44 51" Rear Projection...
Panasonic Rear Projection TV -dark picture
Javabean,
First off I think you meant Panasonic PT-51G44A which is an AP815 chassis. That unit has an all to common failure of the capacitor at C581 on the D board which is a 33uf/160v cap. Replace it and I think that will solve the problem..
Bill
Dec 11, 2007 | Televison & Video
PICTURE DARK
I had the same problem soI decided to go ask at our local tv shop Panasonic warranty place and he was nice enough to tell me the problem . So for everyone reading .. these had a defect with some of the disc capacitors they used on the CRT board it as 2 on there . The second problem is with the ``YC`` chip . panasonic sets have many unusuall malfunctions caused by this chip such as a black & white picture or brightness problems . unfortunatly my set has a bad chip . There we all learned something today . he invites you to contact a Panasonic ``rep`` he will tell you the same thing .
Nov 15, 2005 | Panasonic PT-51G44 51" Rear Projection...
Panasonic PT-51G53 51" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
