Question about ASUS P5QL-E Motherboard, LGA775, Intel P43 + ICH10R, Dual DDR2, PCIe x16, SATAII, RAID, eSATA, Gigab
Asus P5Ql board detects hd and dvd drive but when i set my bios to boot from dvd drive it gives me "reboot and select proper boot device or insert boot media in selected boot device and press a key" I have triple check my wiring; NOTE: Im not using a "valid" vista boot cd, I using one I got from a friend! Please give me your thoughts on this! Thanks in advance!
Posted by gil2199 on
  • gil2199 Mar 31, 2009
    Yeah I kept coming back to that, maybe I just needed to hear it from someone else…off to the store I go! Thanks for the reply!
Anonymous
    President:
  • 948 Answers
It's very simple, the boot cd you are using is not bootable. End of story.
Posted on Mar 31, 2009
Boot Problem in my ASUS Eee PC 900 netbook
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | ASUS Eee 900 Netbook
G31M-VS reboot and select proper boot device or insert boot media
check whether the hard drive is detecting or not, select the first boot device as hard disk
Feb 02, 2013 | Computers & Internet
Unable to boot internal devices? bug?
Did you go into the bios settings and check the status of the hard drive? it would seem that is where the problem lies.
Jul 06, 2012 | ASUS Computers & Internet
My asus desktop with windows vista will not start up. I keep getting a black screen that tells me reboot and select proper boot device or insert media? What is wrong?
It means your system is trying to boot from somewhere other than your hard drive. Make sure you don't have a CD in the CD/DvD Drive. Also when you boot your system pay close attention to which key it says you can hit to change the boot sequence or boot order and which key it says you can select to go into the Bios or Setup. Boot the system the go into the BIOS or Setup. Go to the tab that allows you to select your boot order. Make sure your Hard Drive is selected as the first boot device. Try rebooting after saving and making this change.
Mar 17, 2012 | ASUS Computers & Internet
I dont have boot dissk for my asus f5r laptop what can i do it says reboot and select proper boot device or insert boot media in selected boot device and press a key_
Your ASUS cannot find the hard drive to boot up.
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Mar 08, 2012 | ASUS F5RL-B1 (90NM6A233474421L750Y) PC...
Help with reboot message for Asus G1 notebook.
Sounds like its trying to boot from the Optical drive (cd/dvd drive) thats empty or has no disc in it. You will need to get into the BIOS and change the boot sequence. Select HDDR 1st to boot from your C: drive where your OS is.
Dec 15, 2011 | ASUS G1 Notebook
I CANNOT LOAD WIN7 I cannot get my system to boot from a CD disk (Win 7 Ultimate) I set the BIOS to boot from a CD device - the priority is set for CD first. All other values are default. In...
try to reset bios if does't work try using a usb dvd drive (external dvd drive) remember you do not will be able to read a dvd CD(WINDOWS 7 CD) using a cd burner.
you will need a dvd drive.
Feb 07, 2011 | ASUS Computers & Internet
Reboot and select proper boot device or insert boot media
its basically telling you that your master hard drive with O/S installation cannot be found in the booting system...Check if your master HD is not corrupted and see if your O/S still exist or maybe wiped out..
Mar 31, 2010 | Computers & Internet
Computer beeping and saying reboot and select proper boot device
When you reboot, go to BIOS, restore factory BIOS settings. If that doesn't help, you'll need to reinstall your OS.
Jun 04, 2009 | ASUS Eee PC 1000H Laptop
I am new to building pc's and I've just bought a asus p5ql motherboard, 4gb ram, intel processor and a hd. I have it all together. Green light on board, fans spin, etc. I get the Asus start up screen and...
Just follow these simple steps:
1. Make sure you have all the discs included in your package.
2. After you power-up, strike del key to go to bios/system.
3. In boot selection, select DVD/CD ROM to boot first, HDD second and other if you wish..
4. Press ctrl+alt+delete to restart.
5. After pressing the tree (3), insert your CD/DVD installer to the drive..
6. Follow the instruction...
Good luck and have a nice day!
Feb 16, 2009 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
ASUS P5QL-E Motherboard, LGA775, Intel P43 + ICH10R, Dual DDR2, PCIe x16, SATAII, RAID, eSATA, Gigab Logo
264 people viewed this question
Top ASUS Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Roy May
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
