Your going to need help unfortunately, if you have to ask
Someone with wiring diagrams & testing skills will need to
work on it.
So replacein the security box under the hood wont work?
How would anyone know what problems the car has? You bought a vehicle you know nothing about,the previous owner did something to the car that wasn't there when it was made & your asking about a fire etc Don't see how you would expect someone to help you at all You need to get rid of the add ons & use a wirng diagram to return the car to as built condition
Peter? I kno about the car brother. I do the work on it myself. I jus dnt understand wat would cause it not to stay running. The power wire to the amp cought fire but did not burn the other wires. The car starts but wont stay runin. All I want to kno is wat could cause it not to stay running. I pulled all the fuses out an there all fine. I dnt get what ur saying...
SOURCE: 1998 mitsubishi mirage wont start?
check if the fuel pump is working, if you have someone near the tank and someone else crank motor you should be able to hear a bzzzzzz rom the tank from the pump. if no noise is heard then hit or thump the tank, this can make a fuel pump start to work again, if it starts, then the pump is almost dead
SOURCE: someone took fuses in fuse box under hood and we
yes - there should be a fuse diagram inside the cover and in the owners manual - more than likely you will need ALL of them to start & drive the car
SOURCE: i have a 199 chevy
It is so confusing though I had a go at one sometime and it took a whole lot out of us before we realised that it needed a touch from Chevy garage.
Please visit the Chevy Garage it won't cost you much to fix.
Good luck and thanks for using Fixya.
Rate this solution/ suggestion, please.
SOURCE: 1998 cavalier wont start no spark
If you have no spark try the ignition module, it controls the spark and if you don't have any and the coil is new its the only other option short of wiring or ecu!!
