My hitachi big screen powers up, caption shows up on screen you can tell there is a picture on the screen but it is faint, there are lines running across screen...volume works fine. any body have this problem?
If the lines are slightly diagonal and in red, blue and green you have a problem in the ABL circuit. if the lines are only one color you may take the front grill cover offf and remove the panel. look fro the black box 2 inches square with 6 little controls on it. 3 are for focue 3 are for screen the middle on of the screen is the green adjustment the other 2 should be labled r and b respectivly. what ever the color of the line turn the control labeled screen and r b or g for that color ever so ligtly counter clock wise.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
There are two reasons for this fault. A fault smoothing capacitor at the video output voltage rail, or excess of screen voltage. These lines are called 'vertical retrace lines' technically. Check this link for more details. It has a post, which have information regarding this fault. Go to older posts there.
very possible the YSUS board is going bad .If YSUS is going bad .I would also replace XSUS board since they are same age..Also whenYSUS is replaced make sure you make pot ajdustments as old YSUS and also with XSUS board
I f these lines are slightly diagonal and they all showed up at the same time. you probaly have an open resistor in the ABL circuit. since your set is 13 yrs old, I would not put a penny into it.
You might take the front grill cover off and the panel behind it and find the little black box with 6 little controls 3 are for focus 3 are for screen turn the screen ones ever so slightly counter clock wise. the control in the middle is the green screen adjustment. If the green line goes away try the one labeled r for red and b for blue.
Good Day, LDS also; You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
You may need to set your screens look at the picture when you have a real dark background if there is faint lines in the picture then the screens should be set correctly
KIT10 $29.50 Repair Kit for Hitachi convergence Chassis DP-14G KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
If you mean that a black box appears on the screen, and you can still see the picture around the box, it means that your closed captions are on and set to TEXT. If this is the case, enter the menu, navigate to the closed captions page and set the captions to OFF. If you mean that the top of the picture has collapsed down, the vertical circuit has stopped working correctly and the set should be serviced by a qualified tech.
