Cars & Trucks Logo
Posted on Mar 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Seat belt light staying on
I have a 1999 dodge ram 1500 my seatbelt light is staying on even while it is being worn.
  • Anonymous Mar 28, 2014
    the seat belt light stays on even when im wearing the seatbelt I checked all the wires and there all good and correctly connected
Jeff3fg
Level 2:
Scholar:
  • Expert 124 Answers
  • Posted on Mar 30, 2009
Jeff3fg
Expert
Level 2:
Scholar:
Answers
124
Questions
Helped
48899
Points
381
There is a small clip with one wire on it at the base of the seat belt where it connects to the floor. It might be broken, or the switch inside the belt clip is faulty. If the wire is fine and connected the belt clip side needs replacing
Lairbear
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 3 Answers
  • Posted on Feb 20, 2013
Lairbear
Contributor
Level 1:
Welcome Back:
Answers
Questions
Helped
6338
Points
My 1999 Dodge Ram has three wires coming from the drivers seat, one a LG/RD, has nothing to do with the SCM, unless data is sent from the (IC) Instrument Clusters' seat belt warning lamp driver. Am I correct?
The lamp issue appears during cold weather at times and I'm beginning to think there maybe thermo issues within the IC module?
Plus, when the seat belt is retracted with ignition on, no chime or seat belt lamp indication on IC.
What's going on? And I'm an electronics tech.
I will not replace the IC/SCM/PCM due to high costs...I'll live with this issue.
Any feedback from readers?
  • Lairbear
    Lairbear Feb 20, 2013
    Sorry folks, I referring to a seat belt lamp coming on at random during cold weather.
I have a 2005 caravan that the seat belt warning light and chime will not turn off even when the belts are buckeled..additionally the passenger air bag off light is illuminated even when there is someone...
Pull the fuse it won't affect the seatbelts from working correctly. otherwise you have to disconnect each seatbelt lock to find the defaulted lock. As for the airbag light; do you have the type that can be turned off with a key? It may be permanently turn off and needs to be turned back on with the key.
1helpful
2answers
I HAVE A 2008 DODGE RAM 1500 THE SEATBELT LIGHT AND CHIMES WONT STOP EVEN WHEN WEARING SEATBELT, ALSO NOT REGISTERING WHEN SEATBELT IS BUCKLED
sounds like your seatbelt return wiring might be loose check electrical connections and try to pulling the the seatbelt in and out rapidly to free up return mechanicism good luck
2answers
Why is seatbelt light on and seatbelt not pulling out on my 1999 Dodge Ram 1500?
check the wires under the passenger seat. one is red, one is black. they could be cut.
I have a 200 dodge ram 1500 and the seat belts are stuck any suggestions?
WD 40 is the best first move. Just squirt it right inside the seatbelt latch and work it by pressing the button and putting in and taking back out the other end of the seatbelt. I bet this will do it. The Raz
2005 Dodge Ram 1500. Dimly Flickering center dashboard lights
It is caused usually when the arternator is going bad
1999 ram 2500 4x4 seatbelt light on -not flashing- stays on even with seatbelt on.
check the conectors on the buckels if it's ok then remove pillar cover and check the conector on belt winder
My 99 dodge 1500 quad cab passenger seat belt wont release
get a retractor from a salvage for half price, you need like a torx 50 or 55 to remove the retractor
2helpful
SEATBELTS STUCK ON 1999 DODGE RAM 1500 IS IT A MODULE ?
it is under the center seat. Yes it is the module.
i am having the same problem right now.
trying to find a new one.
Seat belts
These seatbelts are the non-locking type. They only lock when there is a sudden change in the vehicles forward momentum.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
