Question about JCPenney Seiko Men's Titanium Watch
Need to remove winder on mens seiko titanium so i can remove the
Had battery replaced and day and date don't work any longer. too far to travel back to shop. can easily remove back but to take out mechanism need to remove winder
Posted by s_novak on
Anonymous
  • 65 Answers
Ensure crown is in neutral position i.e. pressed home (not in set hands posn.) Remove back and adjacent to the winding stem on the movement there should be a small button (may be indicated with an arrow) depress this gently whilst withdrawing the crown and stem from the watch. Ensure you don't engage to set hands position in the process. You might also find a couple of screws securing the movement into the case. P.S. Usually don't need to remove from case to replace battery.
Posted on Jul 22, 2009
Seiko instruction adjustment instructions day date
The crown ( the winder as used to be) will pull out one ,two, or three stops. Each stop does somthing different.e.g. 1 - hands, 2 - day, 3 - date. Sometimes, the second stop will do two functions - turn one way for day and the other for date.
Jul 22, 2014 | Seiko SGG713P1 Sapphire Crystal Analog...
How to set day/date on an 1968 DX automatic Seiko watch
Seiko watches from this period should have a setting stem that pull out half-way and fully. Pulling the stem out fully permits you to set the time. Pulling the stem out half-way should let you set the date by moving the crown forward/clockwise and set the day of the week by moving the crown backward/counterclockwise.
However, for this to work correctly, the watch must have the correct set stem. I have worked with a number of watches, including Seikos, where a generic stem was substituted after someone accidentally pulled out the crown and stem (Seiko replacement parts can be tough to find in the U.S., especially for discontinued models). If an incorrect stem has been installed, the day/date setting procedure I've just described may no longer work correctly. At that point, setting the date involves advancing the hands to get to the right date; day of the week may not be able to be set at all.
Mar 09, 2012 | Watches
Perpetual 100m 6a32. I had the battery replaced, and now the date is not square in the window. The window shows the bottom of todays date and the top of yesterdays.
Try pulling the crown wheel (winder) to position 2 (1 is fully in, 3 is fully out and 2 is in the mid position).
Turn the winder anticlockwise slightly and this should move the date until it is the correct position.
May 04, 2011 | Seiko Perpetual Calendar with Dark Silver...
I cannot get my Seiko SNA304 chronograph second hand to reset after battery change. Keeps resetting to the 17 minute position, I have tried to use the manual instructions but with no success, Any help...
Seiko watches are a popular accessory for both men and women. The history of Seiko watches goes back to 1881 long time ago, when the company that was to become Seiko began. From the beginning, the method to set a Seiko watch has been designed to be a simple process.
The following are the steps to set a Seiko watch for the time, day and date function, and for setting the chronograph on an analog watch.
Set the Time:
  • THE CROWN
Pull the button on the side of the watch carefully, the crown, out to its most extended position. You will need to unlock the crown if your watch has a locking crown. To unlock, turn the crown counter clockwise. While the crown is pulled out in the setting position, the watch will cease functioning.
  • 12 O'CLOCK POSITION
Turn the crown clockwise to move the hands of the watch past the 12 o'clock position on the dial. The day and date will change to indicate AM setting but will not change for PM setting. It is recommended that you set a Seiko watch in the morning for instant day and date setting; however,this can be done manually.
  • FINISH
To finish setting the time, simply push the crown until it is flush with the side of the watch.
Good luck and thanks for using fixya.
Dec 18, 2010 | Seiko SNA304 Wrist Watch
I just purchased a vintage Seiko automatic DX and I can't figure out how to change the date and day that appears on the watch.
mcdevfito75 here"s how to change the day and date on your vintage Seiko watch, Pull the stem out to the set position and simply turn the stem (winder) every second time around to the 1--2 3 O"oClock position the day will chage, once you get the day push in the stem in all the way, NOW with your fingernail just under the stem (winder) gently lift the stem up to it"s first notch or position, with the stem at this first notch or position, you can turn the stem and the hands won"t move but the date(number) will change, simply go to the correct number / date and your done, push the stem back in a your ready to go.
Jun 22, 2010 | Bulova Watch
I have a Seiko Titanium Chronograph certified water resistant to 20 BAR. The movement # is 7T62-0BZ0. I recently had a jeweller put a new battery in the watch and it has not been working properly since. I...
DO AMASTER RESET TO YOUR WATCH!PULL FULL OUT THE STEM(CROWN)THEN TURN THE HANDS TO THE RIGHT TIME THEN RESET THE CHRONOGRAPH AND THE ALARM WITH THE TWO BUTTONS(SEE YOUR MANUAL.IF YOU HAVENT TRY TO DOWNLOAD IT FROM ANY SITE OF SEIKO SUPPORT).THEN PUT THE CROWN IN.IF THE PROBLEM REMAINS THE ONLY SOLUTION IS THE SIKO SERVICE!THEY ARE NOT EXPENSIVE AND MAKE GOOD WORK!DONT GIVE THE WATCES EVEN FOR THE BATTERY TO THE MONKEYMAGICIANSGURU JEWELERS THEY ARE WATCH RUINERS!
Dec 06, 2009 | Seiko Alarm Chronograph Titanium CASE AND...
Date Changes during the day
Hi Jeffrey, Put stem into "set hands" position and adjust hands to the 12:00 position. Day and date should advance at or close to that time. If you pass 12:00 and there's no change continue rotating another 12 hours and they should advance. Once youv'e found that there's midnight so if you're setting the time at say four (4:00) in the afternoon (pm) you will neew to rotate the hands so around the dial so they pass 12:00 once more then four hours more to 4:00. Now I assume by bilingual you mean that the day ring has like Mon (monday) and Lun for Spanish or the like. In this case if it's showing the wrong languare set the crown (winder) to the first position (second posn is "set hands) and rotate winder eithr clockwise or anticlockwise. Once you discover how to advance the day ring just set it to the correct day/language you want and press the crown home. Hope this solves your problem. If the advances are changing at some obscure time like 8:40 or something it's because the hands pave been located incorrectly and would need correcting by removing movement from the case.
Jul 23, 2009 | Seiko SGG786 Watch for Men
How do you set the day/date on a watch????????
Try this solution I posted earlier for a similar problem.
If you pass 12:00 and there's no change continue rotating another 12 hours (to twelve o'clock again) and they should advance. Once you've found that there's midnight.So say it's now 4:00pm you would need to rotate the hands around the dial again so they pass 12:00 once more (12:00 midday) then four hours more to 4:00.
To set the day/date you can set the crown (winder) to the first position (second posn is "set hands) and rotate winder
eithr clockwise or anticlockwise. Once you discover which direction advances the date and day ring just set it to the correct day/language and date you want then press the crown home.
Jul 17, 2009 | Seiko Wrist 5 SNKA03K1 Automatic...
After replacing the capacitor in my 5J32-OAPO the
It is possible that the second hand is touching the crystal. However, this probably would have only happened if for some reason you remove the movement from the case and in putting it back in it now touches the crystal. If this is not the case, then I am assuming that you have pushed the crown all the way in. Please let me know if any of this works for you. I don't know of any reason that replacing the capacitor would only affect the second hand.
Jul 03, 2009 | Seiko Arctura Kinetic Autorelay #SNG067...
JCPenney Seiko Men's Titanium Watch Logo
1,024 people viewed this question
Top JCPenney Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a JCPenney Watch Expert? Answer questions, earn points and help others
