The dryer takes more then one cycle to dry clothes. i cleaned the trap and under the trap. i also cleaned the hose leading to the wall and the hole the hose connects to on the dryer. i also cleaned what i could reach on the hole in the wall the hose connects to. is there anything else i could do to fix this problem? how can i open up the dryer to check the elements and the drum area for excess lint on the inside of the dryer? the dryer is a hotpoint NVL333EBOCC. i have no idea how old it is. i'm posting on the closest model to what i have.
Pry the top up at the corners and then open the top. now look inside the front panel about 4 inches down on both sides and remove the 2 screws or hex heads holding the front to the cabinet. Remove door switch wires and remove front, carefull drum will drop slightly, you may want to lay it on it's back before removing front panel. from there if you have posted right or close to right model number, the 3 screws you see in the drum, remove them after undoing your belt. remember how you undo the belt so that you can put it back on the right way. Pull drum up out of cabinet and there you will see your heat element. from this site www.repairclinic.com it shows a double element. Might be only one half working causing the lenghthy dry time if this is bad replace it you'll know if one half is bad. Clean all you can while apart you can also slide out the rear bearing out of the bearing cup and apply some high temp grease there. If your element is good change the thermostat. from the looks of this belt make sure the grooves are facing up on the drum or it won't go back on right on the motor and tensioner pulley. I hope this helps you and Good luck.
