Question about NorStar T7316E Corded Phone
Log in to system programming T7316E
I have 6 phones on a BCM 50 system and am trying to log into the system programming to change the name on a few of the phones; I have tried the feature **266344, it then asks for "LOG", what should I place here? The instructions I have found tells me the password is 266344 but does not tell me the log Id.
Thanks in advance
Posted by jwhill8 on
george peters
    President:
  • NorStar Master
  • 860 Answers
The log should be "setnna"(738662) with a password of config (266344) providing it hasn't been changed
Posted on Mar 30, 2009
  • george  peters
    george peters Mar 30, 2009
    your log should be setnna(738662) with a password of config (266344) providing it hasnt been changed
T7316E Corded Phone (nt8b27jaab): I cannot log into system administration to change ...
Try this:
Press "Feature 985" which will display the voicemail extension #. Dial 9, and you will be prompted for a password. Press "RESETSMPSWD". Then log in with the 1020000.
Good Luck!
May 18, 2010 | NorStar T7316E Corded Phone
T7316E voice mail locked
Sounds like you have a BCM or BCM 50 system. Try feature 983 log: 738662 and pswd:266344
Apr 07, 2010 | NorStar T7316E Corded Phone
T7316E Corded Phone
When the display shows LOG: it means that theres no mailbox attached to the extension. When logging in as 120000 theres the possibility of changing the administrator password.To build a mialbox for ext. 25
press feature 983 > log: 120000 > mbox > add > 25 > reset password: next > type: subscriber > ext. 25 > cos: either 1, 3 or 11, >
name: first and last of the employee >directory: y >message light: y > alt ext: none> transfers: blind
Feb 23, 2010 | NorStar T7316E Corded Phone
T7316E forgotten password - need reset
sounds like you might have a BCM 50 Try feature 983, id:738662, pswd:266344. Hopefully the password wasn't changed.
Sep 18, 2009 | NorStar T7316E Corded Phone
Nortel T7316E need to reset all the password
How to Change a Mailbox Password 1. To access the voice mail system press Feature.
2. Press 9 8 3.
3. When you see Log: enter ~ SETNNA (738662) and press OK
4. Pswd: CONFIG (266344)
5. Press "MBOX".
6. Press "CHNG".
7. Enter the mailbox number you wish to reset.
8. Press "Reset".
9. Press "Rls" to exit (orange button to the right of the number buttons).
Default password is "0000".
Apr 16, 2009 | NorStar M7324 Telephone
Norstar T7316e
chang the call log options to none on the specific phone you want it to stop on. or you can go to feature settings and change the call log options to 0 system wide..
Mar 26, 2008 | NorStar T7316E Corded Phone
Nortel Norstar T7316E phone programming
feature 983 it will ask for log number use code 120000 for 2 number extensions, for 3 letter extensions it is 1020000, and 4 is 10020000 once in this screen hit MBOX then CHNG and put in mail box number then hit next until you get to the name and press CHNG and you can change it using the the number corresponding to the letter I hope this helps
Feb 28, 2008 | Lands Phones
Cid issues
Are you getting caller ID?
Under phones/sets, you have to tell the system to log the calls.
Jan 09, 2008 | NorStar T7316E Corded Phone
Nortel T7316E
To reset passwords for Feature 983 do the following
Press Feature 985
Press 9
Enter 73738767793
Press OK
Now go back to Feature 983
Enter 120000 for 2-digit extensions, 1020000 for 3-digit or 10020000 for 4-digit
Aug 21, 2007 | NorStar T7316E Corded Phone
NorStar T7316E Corded Phone Logo
841 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
