Garden Logo
Question about Garden
Snapper SS312 weed eater. Cranks when primed but won't run
Compression tested @ 90 psi. Ultrasonic cleaned carb. with cleaner.
Installed carb kit. Replaced carb to intake gasket. Checked reed valve.
Adjusted metering tab to Walbro specs. Carb type is Walbro WT.
Removed adjusting screws before cleaning carb. Replaced screen in carb. Noticed that primer bulb pumps up hard. All other similar carbs I have worked on, the primer bulb could be continously pumped without any hard resistance. Have tried adjusting screws in all imaginable position. Good spark. With adjusting screws closed almost completely off, motor will crank and run until prime fuel is consumed. The farther I open adjusting screws, the harder it is to crank. If I open them to 1 turn each, motor will not crank.
Any Suggestions besides buying another carb or weed eater?
rmac54
Posted by rmac54 on
  • 1 more comment
  • penraydylan1 Apr 09, 2009
    originally, when primmed fuel would pour out of carb. checked and found diaphram with hole in it. changed diaphram and now primmer button fills and then gets hard to push. any suggestions?
  • Anonymous May 11, 2010
    Have you visually inspected the piston and cylinder?
    Normally you need at least 110 psi.
    hello mr r, sounds like to me you have the fuel lines switched around,this is the same thing that happened to me same problem,
Anonymous
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 109 Answers
I am sorry to say this, but the compression for that type of engine should be atleast 120 psi. Remove the muffler and look at the cylinder, it is scarred beyond repair.
Posted on Apr 22, 2009
3answers
I cannot keep this weed wacker running.
i do not think this is a voltage issue, this a wattage or power out is not enough power in watts to keep the weed eater running, you need to know what wattage the weed eater requires to run.
even though you have a generator that says it will run 3000watts, but in the generator only runs at 1500watts continuously running time until it runs out of gas.
know lets say your generate say 2000watts, that means you are only going to get 1000watts continuously unit you run out of gas.
How to fix my Weed Eater MAX TE475Y TWIST 'NEDGE that wont start
First diagnose whether its a fuel, ignition, or compression problem. Remove the air filter cover and air filter. Spray a shot of carb cleaner into the carb and attempt to start ( choke should be open, throttle closed). If the unit starts on the prime then you have a fuel problem. Proceed by rebuilding the carb and if the fuel lines or primer bulb are brittle or discolored then replace them as well. Be sure that you use fresh fuel ( less than 2 weeks old) and if ethanol is in your fuel be sure there is no water in your fuel. If the unit doesn't start on the prime then check spark and compression. Compression should be between 120 and 140. If less than 90 the unit should be replaced.
Aug 24, 2014 • Garden
I have a mity lite 26cs weed eater. I cannot get it to fire let alone run. The compression is 80 psi and I cleaned and installed a new carb kit. Doesn't seem to matter where I set the needles it won't run....
I would recon that the the little fuel filter in the fuel reservoir tank is congested, or that the hoses feeding the fuel has deteriorated, have had a number of them display these issues, also check the the primer dome, if that leaks or has deteriorated it will also present problems, finally just double check your fuel mixture, good luck, these things can challenge your resolve
Feb 03, 2018 • Garden
3helpful
Craftsman 29cc 4 cycle weed eater. Cranks but will only idle. Seems to bog out. Will only run in full choke at idle. Have changed gas and checked lines for leaks or stoppages. None found. Can not...
remove the sediment bowl on the bottom of the carb,but dont lose the gasket and watch out when the float drops so the needle and spring in the bore dont fall and you lose them,then clean out any dirt in the bowl and in the needle seat andget some carb cleaner and throughly clean out all openings in the carb,its a california carb thats why there are no adjustments
8helpful
2answers
25cc weed eater, will only idle
double check your carb as it should have a screw for the fuel mixture. some carbs have a plastic piece over them that only lets you move the screws so far if you need more extreme adjustment they pull out about a 1/8th of a inch then you can turn in then push it back in, same principals as making a flame on a bic lighter bigger, if you cant find it take some pics of your carb and email them to me @ [email protected] and i will point them out
1helpful
No Gas to Primer Bulb
It sounds like the carburetor needs cleaned. Take the carb. apart and clean it with carb. cleaner. Use a Den Tech Brush, (used for cleaning teeth), they are perfect for cleaning the small ports in carb. If that still doesn't work, you may need to buy a carb. kit for your weed eater. If so, replace the gaskets and valve needle, and also make sure to replace the small screen. this should all come in the new carb. kit.
Home lite weed eater
the fuel rails inside the carb could be clogged, try cleaning with carb cleaner and blowing out the rails with compressed air. or the car may need replaced.
Nov 04, 2008 • Garden
Top Garden Experts
john h
Marvin
Marvin
wadingriver
wadingriver
