Question about HP Photosmart C3180 All-In-One InkJet Printer
Unable to add a functioning (second) printer, for greyscale.
I have Windows Vista. Doing ''Add Printer''. The new printer added ''successfully'', but hovering over printer, shows ''error'', and wont print.
Printer is HP Photosmart C7280 All-in-one.
Intended this copy of my C7280 to be set with greyscale property, but cant get a working 2nd printer.
Had no difficulty adding a greyscale printer in XP.
Anonymous
Clicked on Start/Control Panel/PrinterI. Clicked Add a printer. Obtained (Copy 1) of my HP Photosmart C7280 all-in-one printer. Right clicked on (Copy 1)/properties. Opened Ports tab. Saw comment "Print to the following Ports. Documents will print to the first free checked port." A listed USB Virtual printer port, showed three printers -- my first printer, my copy 1 (& my fax printer) -- was unchecked. I placed a checkmark in this Port box. Both the original printer, and my copy 1 printer are printing just fine. *I have not checked to verify that my fax is functional.
I did rename the original "color". I renamed Copy 1 as "grayscale", and --under printer preferences, checked, under "color options", to print in greyscale.
Posted on Mar 31, 2009
How can I share my HP officejet 5610 all in one printer that is connected to my desktop that has windows XP with my windows vista laptop?
1. Unplug your USB cable from the back of the Windows XP PC and plug the USB cable directly into your Windows Vista PC.
2. The Windows Vista drivers for your printer should be automatically loaded and your printer will be installed on your Windows Vista PC. If this was successful, skip right to step 3.
If step 2 is not successful
i. Download the Windows Vista printer driver for your printer from
the manufacturers website.
1. If your printers manufacturer has not created a Vista driver
yet, retry step 2.
ii. Install the driver on your Windows Vista PC. During
installation, youll be prompted to connect the printer to your PC.
Choose the option to proceed with installation without connecting the printer.
3. After installation is complete, open the Printers icon in the Windows Vista Control Panel.
4. Right-click on your printer that was just installed and choose Properties.
5. Navigate to the Ports tab.
6. Click Add Port, then select Local Port, then click New Port.
7. For the Port Name, enter the exact network path and share name of your printer. (ex. - \\HOMEPC\Printer2) 8. Click OK and make sure that this new port is selected with a check in the checkbox.
9. Click Apply and then OK to close the printer properties.
10. You should now be able to print from your Windows Vista PC to a shared printer located on your Windows XP PC.
Jun 17, 2010 | HP Officejet 5610 All-In-One InkJet...
Tip
Alternate way of networking a Windows7/Vista system to a Windows XP systems's...
If you have tried the normal printer wizard process and were unable to get a printer to function, then verify the network name of the computer that has the shared printer and the share name of the printer, then follow these steps. Worked for Me.
Windows 7
Go to CONTROL PANEL. Choose DEVICES and PRINTERS. The choose ADD PRINTER.
Choose ADD A LOCAL PRINTER. Click on CREATE A NEW PORT. Select in the drop down box, LOCAL PORT. Click NEXT.
A dialogue box will appear asking you to enter a port name. Type in: \\computername\printername
In Vista
Go to CONTROL PANEL. Choose PRINTER. The choose ADD PRINTER.
on Mar 25, 2010 | Computers & Internet
Tip
How to use a printer?
Install a New Printer DIY installation of your new printer in Windows. You may have a new printer with an installation disc, or maybe a second hand one with no disc. Either way you will find out how to install your printer onto your computer.
Add Network Printer If you have two or more computers in your house or office you will only need one printer installed on one computer for both to have printing privileges. This article shows you how to add a network printer to Windows Vista.
Add Network Printer Applies to Windows XP. Even though the instructions are similar to installing a network printer on Windows Vista, there are a few extra tips that might be interesting.
Enable Printer and File sharing How to enable in Windows XP And Vista. If you want to share a printer on your network you must enable printer sharing. It is not hard to do but it will not work if it is not enabled.
Path to your network printer How to find the path \\server\printer. If Windows does not find your network printer automatically then you will need to know the path to your network printer.
Set Network printer permissions Set who can change printer settings in Windows XP and Vista. I personally like to let everyone on the network just print and not be able to change too many settings to do with the printer.
Network printer has problems printing - You do not have permission to use selected printer.
Quick Printing Trick Cool printing trick for Windows Vista and XP.
on Jan 18, 2010 | Office Equipment & Supplies
Trouble adding hp laserjet 1000 series printer
You need to download drivers for windows vista. They are supported in windows 7. Go to www.hp.com, click on "drivers and support", enter your printer model, and download the drivers for windows vista.
Hope that will help solve your problem!
Apr 27, 2010 | HP LaserJet 1000 Printer
Can't add 2 vista computers to Dell wireless printer adapter 3300
Is the printer a networked printer or is the printer attached to a computer?
Jun 04, 2009 | Dell Inspiron E1705 Notebook
Unable to install printer
Step one: Determine the appropriate compatible driver
Since there is no driver for the deskjet 656, the hp site says the alternative driver would be for the deskjet 660c. There is no need to download it as it comes with Vista, but we will need to install and configure it.
Here are some directions:
Step two: Install the driver
1. Verify that the Universal Serial Bus (USB) cable is not connected to the printer.
2. Click the Windows icon ( start ), click Control Panel , click Hardware & Sounds , and then click Printers .
3. Click Add a printer .
4. Click Add a local printer .
5. Select the Use an existing port check box.
6.In the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
7. Under Manufacturer on the Install the printer driver dialog box, select HP .
8. Under Printers , select the appropriate alternate driver for the printer (in your case, the 660c) , and then click Next .
9. In the Printer name text box, type the printer name, and then click Next . The printer driver starts to install.
NOTE: The name of the alternate driver displays as the default name. Change this name to the name of your printer, if desired.
10. After the computer displays a message that the printer was successfully added, connect the USB cable to the printer and to the computer.
11. On the Found New Hardware screen, click Cancel .
NOTE: If multiple pop-up windows display, click Cancel on each window.
Step three: Configure the driver
1. In the printer folder, right-click the name of the printer, and then click Properties .
2. Click the Ports tab.
3. Change the port from LPT1 to USB
4. Click Apply .
Step four: Print a test page
1. Click the General tab.
2. Click Print Test Page .
Dec 15, 2008 | HP DeskJet 656c InkJet Printer
New comuter with windows vista and can not load printer hp photosmart 7660
1. Verify that the Universal Serial Bus (USB) cable is NOT connected to the printer.
2. Click the Windows icon, click Control Panel , click Hardware & Sounds , and then click Printers .
4.Click Add a local printer .
6. In the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
8. Under Printers , select "Deskjet 5600"
Now let's configure the driver
3. Change the port from LPT1 to USB.
Now let's make a test
1.Click the General tab.
Your printer should start printing in a few seconds.
Dec 02, 2008 | HP Office Equipment & Supplies
Need Help Adding a Printer
You do not use the Windows Add Printer option for HP printers. Reinstall using the HP installation CD or downloaded package and follow the instructions. The HP installation wizard should prompt you when to connect the printer.
Nov 28, 2008 | HP PhotoSmart C4280 Laser Printer
Cannot load printer onto vista op syt. from windows 98. do you have update for vista op sys. I have a canon inkjet i70 printer.
Go to this link and type "vista drivers" in the search window in the center of the screen and click "Search". Click on "Does my product support Windows Vista". This will explain that Windows Vista already contains a driver for your i70 printer. If you want to have the full functionality, you can download and install the Add-on Module. Go to this link, select Windows Vista as OS and you will see the Add-on Module available for download.
Sep 19, 2008 | Canon Office Equipment & Supplies
HP OJ 7410 printer disappeared
Nothing to worry about. Go to HP.com and from there select Software and Driver Downloads. Download the Full feature software and driver for windows Vista. Run the Installation.
If the softwares are installed it will ask you to "Add a device". Add a device and select network option. The device will be installed. Now there is a patch on HP.com for unexpected uninstallation. Download it and install it on the computer. It will resolved the issue.
Feb 16, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP Photosmart C3180 All-In-One InkJet Printer Logo
148 people viewed this question
Ekse
efs_perpends
efs_perpends
