Tomtom Go 530T GPS Receiver Logo
Posted on Mar 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not able to message with tomtom go 530
I am not able to message with my tomtom go 530, the actual logo "Read/Write message" on the menu is highlighted for use but once i hit the option the rest of the option such as "write message" does not seem to b available, why cud this be???
Anonymous
Level 2:
  • Expert 515 Answers
  • Posted on Apr 17, 2009
Anonymous
Expert
Level 2:
Answers
515
Questions
0
Helped
249944
Points
771
Maybe your cell phone isnt compatible with your device, please see list here:
http://www.tomtom.com/phones/compatibility/
Green screen
1.) Press and hold down the "Menu" key until the manufacturer's logo appears on the screen. This could take up to a minute or more. Release the "Menu" key when the logo appears.
2.) Immediately press the "9," "8," "7" and "6" keys in this order. Press the "Enter" button on the remote to enter the "Service Menu" screen.
3.) Press the "Menu" button to go to the second of the two "Service Menu" screens. Press down on the "Down" arrow until you highlight "Color Calibration." Press the "Enter" button to enter the "Color Calibration" screen.
4.) Select one of the color bars on the screen. Adjust the color by changing the values of the color bar by pressing left and right on the "left" and "right" arrows on the remote. Repeat this procedure with the other color bars as well. Stop adjusting the colors when the green cast is no longer present.
5.) Press and hold the "Power" button on the remote to exit the "Service Menu" and save the adjustments you have made.
Now turn the T.V. off. When you turn it back on it should reflect your personal preference.
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM4Pfcki
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3rDVkt
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3hkBLp
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3VlPaY
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3H5rYm
I am getting an animated message which is a picture of the tomtom with a blue SD card coming out of it then a no waiting sign appears. Also, when using the TomTom computer package on my mac it keeps...
It doesn't look good. It could be that the unit has been formatted accidentally, the SD card has become corrupted or the reader damaged.
If it is a config problem, the unit can be reset to factory settings.
To reset your TomTom device, do the following:
  • Check that the battery is charged properly. Charge your device for at least 2 hours before trying to turn it on again.
  • Reset your navigation device. Press and hold the On/Off button until you hear the drum sounds and the device restarts. This can take 30 seconds or more.
You can read more about it at tomtom's support site:
http://au.support.tomtom.com/app/answers/detail/a_id/8820
How do I change the battery on a tomtom go 530
Replacing the TomTom Go 530's battery is actually not all that hard as this video demonstrates:
The company that produced the video sells a kit which includes the battery and tools necessary to do this yourself if you'd like. See: http://www.newpower99.com/ProductDetails.asp?ProductCode=TOMTOM+GO+530&Show=ExtInfo I swapped the battery of a friend's dying GPS using the aforementioned kit and all went well. His Go 530 is back up and running smoothly.
Hope this Helps, aaron
6helpful
The company that produced the video sells a kit which includes the battery and tools necessary to do this yourself if you'd like. See:http://www.newpower99.com/ProductDetails.asp?ProductCode=TOMTOM+GO+530&Show=ExtInfo I swapped the battery of a friend's dying GPS using the aforementioned kit and all went well. His Go 530 is back up and running smoothly.
Cannot read disk
"A disk read error occured press Ctrl+Alt+del to restart " FOLLOW THE BELOW INSTRUCTIONS TO RUN DELL DIAGNOSTIC ON INTERNAL HDD Open the Dell Diagnostics on either your hard drive (F12) or from the Resource (Drivers and Utilities) CD. Running from the hard drive is the preferred method of using the diagnostics. If problems occur when running from the hard drive or there is no Utility Partition, the diagnostics can be run from Resource (Drivers and Utility) CD. From your hard drive: Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. When the boot device list appears, highlight ?Boot to Utility Partition? on desktop systems or ?Diagnostics? on portable systems and press . Note: On portable systems, PSA will be executed first. When PSA completes, press any key to load the Dell Diagnostics.? Go to step 2. NOTE: If you receive a message stating that no Diagnostics utility partition has been found, follow the instructions on the screen to run the Dell Diagnostics from your Resource (Drivers and Utilities) CD. From the Drivers and Utilities CD ResourceCD: Insert the Drivers and Utilities CD into the CD drive. Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. NOTE: This feature changes the boot sequence for one time only. On the next start-up, the computer boots according to the devices specified in the system setup program. When the boot device list appears, highlight IDE CD-ROM and press . Select Boot from CD-ROM option from the CD boot menu. Select Run the 32 Bit Dell Diagnostics numbered list. If multiple versions are listed, select the version appropriate for your platform. Go to Step 2. After the Dell Diagnostics loads, the Main Menu appears. Click the button of the option you want. If a problem is encountered during a test, a message will display the error code and a description of the problem. Write down the error code and problem description and follow the instructions on the screen. If you can not resolve the error condition, contact Dell. If you run a test from the Custom Test or Symptom Tree option, click the tabs above the right window for more information: When the tests are completed, if you are running the Dell Diagnostics from the Drivers and Utilities CD, remove the Drivers and Utilities CD. Close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and restart the computer, close the Main Menu screen. Regards Sunil Dsouza
Tomtom Go 530 Bluetooth Conectivity Problem
Any help with this as mine (530) is doing the exact same?
Jun 15, 2009 • Tomtom GPS
1helpful
Image is upside down
Hit the menu/select button to bring up the menu either on the projector or on the projector remote then go down until advanced is highlighted then press the menu/select button then move down until Ceiling Project is highlighted and hit the menu/select button again to get the image right side up. If you have the manual for the projector this information can be found on page 34.
Text message
  1. Tap Mobile phone in the Main Menu.
  2. Tap Read/Write Message.
4. Tap the message, and tap delete ( should be along the bottom menu bar )
As the unit uses blue tooth, it may also update changes made by the phone itself. Try deleting messages from your phone to see if it will update the change.
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
