Question about Vivitar 283 Flash
Vivitar 283 not firing on Nikon FM
Hi! I recently bought a Nikon FM and a Vivitar 283 flash seperately on ebay. The flash seems to work and fires when I press the open flash button, but once it's mounted on the camera (on the hot shoe) it doesn't fire when the shutter is pressed. I guess this would be a problem with the hot shoe connection? Is there anything I can do about that? Thanks!
Posted by Luke Chidgey on
TC CAMERA REPAIR.Com
  • 176 Answers
Did you get the cord with the flash unit, If so then try that to see if it's the camera, Cords are cheap to buy if you didn't rec it,
Posted on Sep 22, 2017
2 Related Answers
Anonymous
SOURCE: vivitar 283 won't flash, exept through pc terminal
Hi if it is a Japanese 283, CAREFUL, you are working with ~300V
remove the sensor from the front. Short out the terminals at 7 o'clock and 11 o'clock with eg a paper clip, and then charge up the flash . Short the centre terminal with the one at 7 o'clock. If the flash fires, then it probably needs a replacement hot shoe from ebay. If it doesn't, it is a simple job to fix for an electronics worker. Manuals are available on ebay.
I repeat, careful with the Japanese flashes, you will have ~300 volts near you fingers, so if you are less than 100% confident that you won't blow the top of a finger (or worse), get an electronics worker to look at it.
Don't use the ebay hot shoes on a 300 volt flash, you will have the 300 volts out in the open and ready to bite you - have a look how well hidden the second contact is on the Vivitar plastic hot shoe.
Good luck the Feral Photographer
Posted on Jan 05, 2009
MIke
  • 685 Answers
SOURCE: Hi my name is Curtis can you tell me IF my Vivitar
No the 283 is not compatible with your camera. The 283 is manual only and not TTl. The canon flash is also not compatible with your Olympus. You need an olympus compatible flash.
Posted on Nov 27, 2009
I have a nikon d3200/vivitar 283/wein voltage adaptor/good sync cords and still no flashoutput,help rick
just to exclude anything faulty, start with the flash on the camera and check if it works. Also check the camera settings. On your Nikon you can chose flash off. Don't do that. If you get the flash working on the camera then you starts with the extension cord and it still should flash in the same conditions.
May 06, 2014 | Vivitar 283 Flash
Vivitar 283 won't fire
Since the flash is working on test, it means the connection to the camera via the hotshoe is not working. With the flash on and ready light showing that the flash has charged, take a small thin copper wire and short between the the metal spring on the side of the hotshoe (in the slot) and the round metal contact tip of the hot shoe. This should cause the flash to fire if the internal connections to the shoe are working.
If the shoe is working then it must be the camera that is not working. Many modern digital cameras cannot fire older flashes directly, because the voltages on these older flashes are too high. This could damage the camera or if the camera has protection against the high voltage, that will make it impossible to fire the flash. In that case you need an adapter. These are available cheaply. You should try borrowing a modern flash to test that your camera is still working and has not been damaged, if it is a modern electronic camera.
Nov 26, 2017 | Vivitar 283 Flash
Vivitar 283 on a digitial camera?
It depends on the variant of the 283. Take a look here.
Aug 27, 2012 | Vivitar 283 Flash
Can the Vivitar 283 be used safely on Nikon Digital SLR Cameras?
I assume you're asking about the 283, not the DF-283 which is compatible with digital cameras.
As for the 283, yes, if you put an adapter such as the Wein Safe-Sync between the camera and the flash. Under no circumstances should the flash be mounted directly on the camera.
Nov 29, 2009 | Vivitar 283 Flash
Hi my name is Curtis can you tell me IF my Vivitar 283 flash will work on my c-750 Olympus, TTL camera it have an hot shoe,but flash don,t fire. I have talked to Olympus about it(on answer). I took it to a...
Nov 16, 2009 | Vivitar 283 Flash
Vivitar 283 with new Nikon Digital camera
the nikon D80 has a 250 volts safe range and i have the same issue but readin on the internet i learned that yo can now the voltage of your flash with a voltage metter ond the hot soe.
Vivitar 283 has diferent ranges of voltages depending on the year of fabrication so older ones can achieve 300 volts and earlier have 230 volts so the best is to get a vivitar 285hv for about 75dollars or a safe sync for about 55dollars, you can find all on ebay or other brouser the safe sync converts up to 400 volts to a safe 6 volts that are yust the normal voltage for digital flashes.
Jan 06, 2009 | Vivitar 283 Flash
Vivitar 283 won't flash, exept through pc terminal
Dec 14, 2008 | Vivitar 283 Flash
Vivitar 283 flash will not work on camera.
To test everything except the camera, just short the contacts on the Wein protector. If the flash fires, the problem is in your camera, and maybe the protector did not do its job as good as expected.
Good luck
Aug 29, 2007 | Cameras
Vivitar 283 Flash Logo
136 people viewed this question
Top Vivitar Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Barbat Nae
Barbat Nae
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
