Question about Sony DCR-HC20E Mini DV Digital Camcorder
I've had this for three years with not a single problem.I turned on yesterday and found that when set to play/edit mode the buttons on the touchscreen don't work.In the manual it says I should calibrate it and I followed all the steps exactly as the manual said but it didn't work. It might help if the manual said what happens after you touch the cross on the screen when calibrating, all that happens is the cross moves to one of three positions, it doesn't say what you're supposed to do after the cross has moved. I would rather avoid taking it for repair if there's anything I can do to get it working myself.
The flexwire is the problem of your camera and if all wiring will be cut the next stage of problem is the lcd monitor would not turn on...go to a service center for replacing or repairing the flexwire...is not easy for repairing that if you are not a technician that wiring is like a strand of hair that why is difficult to fix but in our shop we modified that and become more durable than the original...
Posted on Sep 05, 2007
If the touch screen of the Camcorder is not working, please
follow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
Note: 8 represents the reset button on the above figure.
If the issue persists again, please perform LCD screen Calibration and check if
that helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, please
remove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15
seconds, turn the Power switch to OFF position and then reinsert the battery
pack.
If the issue persists even after performing all the above-mentioned steps,
service is required.
I hope this information will help you to resolve the touch screen issue of the
Camcorder.
Note: Please make sure that the Camcorder is turned ON while pressing the reset button.
that helps.
pack.
Camcorder.
that helps.
pack.
Camcorder.
that helps.
pack.
Camcorder.
that helps.
pack.
Camcorder.
I didn't say the LCD screen doesn't turn on. The camera fixed itself after I just left it for 24 hours,I wonder how much your shop would have charged for that.
i have the same problem only worse! the calibration of the screen won't start either!
