Car Audio & Video Logo
Posted on Mar 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My kenwood kdc-3011 has two blue and two yellow wires and have it all wired but the 7 wires they are 2 yellows 1 blue wire 1 blue wire with white strip 1 orange wire 1 red wire and one black wire now i am sure the black wire is for the ground and i think that the orange is for illumination but as for the yellow i know that one is for 12+ unswitched but dont know what one please i need a wire diagram for it
Anonymous
Level 3:
  • Master 15,935 Answers
  • Posted on Mar 30, 2009
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5034010
Points
35540
CLICK HERE for your owners manual.
P.25 has a wiring diagram.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
I need a wiring diagram for a kenwood cd receiver kdc-448u
Red..accessory
Yello..constant...battery..
Black..ground..
Blue/yellow ...steering ..
Blue/white..remote..
Blue..antenna..
All speaker wire wuth black..negative..
All solid color is positive
2answers
Is their other harness connects fit kenwood kdc mp228 cause my harness the I'm missing some red and black and yellow wires from wiring harness
Hi, this picture resembles the harness(connecting plug) looking in from the back of the harness. The red wire goes into the A+ point. the black wire goes into the Gnd point. The yellow wire goes into the B+ point. if you not sure how to read this picture please ask the help of an installer. Cheers.
2answers
I need a wiring diagram for a 1995 Honda Civic for my kdc-mp538u
Car Radio Constant 12V+ Wire: Blue/White
Car Radio Switched 12V+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Radio Dimmer Wire: N/A
Car Radio Power Antenna Trigger Wire: N/A
Car Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2?
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: 6 1/2?
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
1helpful
I'm trying to hook up a Kenwood kdc x492 to a 96
Battery is yellow
Accessory is white/red
Ground is black
Illumination is red/black
Power antenna is yellow/white
LF speaker +blue/green - grey/black
RF speaker +red/green - brown/black
LR speaker +blue/yellow -grey/white
RR speaker+red/yellow -brown/white
1helpful
Need a stereo wiring diagram
Hiya,
Here's the wiring connections for the Kenwood KDC-3025.
Black: Car chassis (-) ground wire
Yellow: Battery (+) wire (must connect to retain memory settings)
Red: Ignition/Accessory wire
White (w/black stripe): Front Left speaker (-)
White: Front Left speaker (+)
Gray (w/black): Front Right speaker (-)
Gray: Front Right speaker (+)
Green (w/black): Rear Left speaker (-)
Green: Rear Left speaker (+)
Purple (w/black): Rear Right speaker (-)
Purple: Rear Right speaker (+)
Blue (w/white): Power Control wire (used with ext. amp only). Do not expose this wire, if no amp is used.
Blue: Antenna Control wire
Brown: Telephone Mute wire (used with handsfree carkits).
Hope this helps,
Cheers,
Scott
Kenwwod KDC MP 543u Protect mode problem
This indicates a short in one of the speakers, or possibly the speakers are not wired correctly. Please see my tip at http://www.fixya.com/support/r9389300-stereo_says_protect_or_clicks_off_when .
Correct wiring for 95 Corolla is as follows:
1995 Toyota Corolla Wiring harness, Kenwood wire color
Radio Constant 12V+ Wire: Blue/Yellow, yellow
Radio Switched 12V+ Wire: Gray, red
Radio Ground Wire: Brown, black
Radio Illumination Wire: Green, not used by Kenwood--please tape off
Radio Antenna Trigger Wire: Black/Red, blue
Left Front Speaker Wire (+): Pink, white
Left Front Speaker Wire (-): Purple, white/black
Right Front Speaker Wire (+): Light Green, gray
Right Front Speaker Wire (-): Blue, gray/black
Left Rear Speaker Wire (+): Black, green
Left Rear Speaker Wire (-): Yellow, green/black
Right Rear Speaker Wire (+): Red, purple
Right Rear Speaker Wire (-): White , purple/black
Trying to find a wiring diagram to install my kenwood kdc-mp342u into my 2001 grand am. any ideas?
Please let me know if you have any questions, and thanks for using FixYa.
2001 Pontiac Grand Am Car Audio Wiring Diagram kenwood kdc-mp342u
Car Radio Battery Constant 12v+ Wire: Orange yellow
Car Radio Accessory Switched 12v+ Wire: none
Run a wire to the fusebox for switched power. red
a 14 gauge wire will do--use a 15 amp fuse
Car Radio Ground Wire: Black/White black
Car Radio Illumination Wire: Gray (tape this wire off) none
Car Stereo Dimmer Wire: Brown (tape this wire off) none
Car Stereo Amp Trigger Wire: Pink blue
Left Front Speaker Positive Wire (+): Tan white
Left Front Speaker Negative Wire (-): Gray white/black
Right Front Speaker Positive Wire (+): Light Green gray
Right Front Speaker Negative Wire (-): Dark Green gray/black
Left Rear Speaker Positive Wire (+): Brown green
Left Rear Speaker Negative Wire (-): Yellow green/black
Right Rear Speaker Positive Wire (+): Dark Blue purple
Right Rear Speaker Negative Wire (-): Light Blue purple/black
Amplifier Mounted behind trim in the left side of the trunk.
I need to install a kenwood kdc 138 in a94 ford tempo and need to know what to hook in what were
1994 Ford Tempo Stereo Wiring Constant 12V+ Green/Yellow Switched 12V+ Yellow/Black Ground Red or Black Illumination Blue/Red Dimmer n/a Antenna Trigger n/a Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Orange/Green Left Front (-) Black/White Right Front (+) White/Green Right Front (-) Black/White Rear Speakers 5" x 7" Rear Deck Left Rear (+) Pink/Green Left Rear (-) Pink/Blue Right Rear (+) Pink/Blue Right Rear (-) Green/Orange download the manual for the radio and see what on the radio goes to the wires here
Neeed to know what wire go to what on a 1994 ford tempo trying to hook up kenwood model kdc138?
1994 Ford Tempo Stereo Wiring Constant 12V+ Green/Yellow Switched 12V+ Yellow/Black Ground Red or Black Illumination Blue/Red Dimmer n/a Antenna Trigger n/a Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Orange/Green Left Front (-) Black/White Right Front (+) White/Green Right Front (-) Black/White Rear Speakers 5" x 7" Rear Deck Left Rear (+) Pink/Green Left Rear (-) Pink/Blue Right Rear (+) Pink/Blue Right Rear (-) Green/Orange any more info let me know go to http://www.tintingbyfredjohson.com to email me
1helpful
2answers
How to install kenwood kdc-x493 with kac-8104d in 1996 honda civic?
very simple on the back of the deck you will have a wire harness
Yellow = constant power supply
Red = Switch power supply
Black = Ground
White = left front speaker +
White /Black stripe = Left Front speaker -
Grey = right front speaker +
Grey /Black Stripe = right front speaker -
Green = left rear speaker +
Green w/ black stripe = left rear speaker -
Purple = right rear speaker +
purple w/ black stripe = right rear speaker -
wires for the honda are,
Constant 12V+ Blue/White Switched 12V+ Yellow/Red Ground Black Left Front (+) Blue Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6" x 9" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
