Need the correct wiring schematic for the LXR end on a Shure SM57
It has 3 prongs but I only see 2 wires both with red insulator
red insulator copper weire
red insulator -silver wire
appreaicted any help on this !
The wire coming from the switch if it has one will go to pin 2 as it is hot(+ve). Pin 3 is cold (-ve) and pin 1 is gound/shield which will make contact when the XLR connector is mounted back in the mike secured with the set screw. There should be a small hole in the side of the base of the mike that the set screw lines up with. Usind the correct size of flat bladed screw driver, back this screw out counter clockwise to secure the connector. If that is wrong, get back to me and i will hunt up my Shure wiring diagrams. If pin 2 and 3 are backwards the mike will be out of phase. Hope this helps.
