This is a jigsaw miscatagorized as a chainsaw. Do you have a blade big enough to drop 24" tree? We don't answer jig saw questions in the chainsaw section.
You can try spraying some lubricant into the blade holder. Sometimes the "ball" in the shaft gets stuck from dirt. Otherwise you will need to disassemble it by removing the roll pin that holds the collar on the shaft.
Its hot pressed onto the shaft its made not to come apart because if it did in use it would not be good. I use sawalls all of the time and fine if the blade snaps low you can get them out with a strong magnet if you hold it up side down and turn the collar shake it around mabey spray some WD40 in side first it may take a little doing but it beats takeing that change collar a part.
Remove 2 screws from under front grip and the swivel foot should slide forward and out (might need a bit of a twist to loosen) plastic grip should now slide forward and off.
Look at the base of the blade, there is either a half twist quick disconnect or an allen screw.
Safety first: Unplug the saw.
If its the allen screw it will be located to one side of the blade. Just loosen it , pull the blade out.
The half twist ring doesa what its name implies. Twist it as far as you can (holding the saw with the bladed to the ground allows it to drop out) to free the blade.
At the base of the blade where it attaches in the saw you will see a round in shape with ridges fixture. Turn it so the slot is in line with the blade. Then you will be able to remove the blade. If the fixture does not turn, move the blade up and down while you turn the fixture.
