LG RD-JT91 Multimedia Projector Logo
Anonymous Posted on Mar 30, 2009
I need to re-set the lamp counter to zero on a projector RD-JT91 I read to press the exit button but I cannot locate that. Where is it as it is not on my remote
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 31, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
344
Points
Sent the unit to the agents here to replace the lamp did not relish having to do it myself Thanks anyway
Cannot reset lamp counter on benq mp620 projector, projector bulb has been replaced but lamp counter warning is displayed on startup and requests buld change and reset of counter. So I'm stuck in a...
Hi, I don't know if this is to late but oh well, hold down the exit button on the projector panel for 5 secs, and then press auto on the same panel after, this should reset the hours back to a lovely zero
A vertical white strip appears after few minutes.
Hi fabiano did you ever find a solution the vertical line in your RD-JT91 Multimedia OH projector. I now have the same problem. Gary
3helpful
Lamp reset timer
Hi there
There is basically two ways to reset the lamp timer :
1. ) On the Projector's physical buttons
Arrow Keys - Up , Down , Left , Right then Menu and Enter - this should be done quickly whilst the Projector is in standby mode.
2.) Switch Projector on - Hold in the Up Arrow Key on the physical buttons on the Projector untill a PIP screen appears - then just follow the on screen steps.
2answers
LG RD-JT 21
Hi Mike
Press the following buttons quickly - Up , Down , Left , Right , Menu & then Enter - this should reset the timer.
3helpful
Resetting lamp on a lg rd jt40 projector
remove bulb. replace bulb. within ten minutes press exit on projector and hold for three secs. then immediately press menu then press left or right arrow button. you are done. turn off then turn on
LG RD-JT91 PSU problem
Hi there
On the left hand side where all the inputs are located you will see a very small screw , that is most probably what's keeping you from opening it.
Also remember to take off the cover to the front and do this slowly because the translation board's lint is attached to the top cover. Once open you can just unhook it and then you'll be looking for the board with the AC inlet on it.
1helpful
LAMP goes off after few minutes
1-check the counter reading of lamp to see if it is in the right age of lamp or not.if it is in right age the problem still in power unit or in ballast.
2answers
Help me Please
I have just reset my lamp! Disconnect all cables but the power, switch on it will search for a source, the lamp timer message will display press exit untill it will give you a message to press menu to reset the lamp timer, it will give you a option to press left or right to reset. I used the buttons on the projector not the remote.
2answers
Reset the bulb
1-press the exit button on the projector for 3 second to display the total used lamp time.2-press menu button on the projector during the lamp hour message- an adjustement message will be appear press right or left arrow to reset timer to zero.if success osd change to(lamp hour reset ok!)
Top LG Office Equipment & Supplies Experts
ADMIN Andrew
ADMIN Andrew
bvmihai
Aron
Are you a LG Office Equipment and Supply Expert? Answer questions, earn points and help others
