Nintendo NES Console Logo
Posted on Mar 30, 2009
Fuzzy picture on TV and NES when new RF adapter is cconnected
I bought a new rf adapter for my original NES, and when i connect it, both the television and the gameplay picture becomes fuzzy. Why could this happen?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 13, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
921
Points
I had the same problem, and it was the rf unit itself. to resolve this problem i went to radio shack and purchased a special connecter. one side is an rca (male) to rf (female). when attached to a standard peice of cable wire, it acts as an rf unit. Also works with the sega genesis. hope that helped
1helpful
Super nintendo
Original-Style Super NES RF to VCR Hookup
Installation Steps:
Locate the VCR's VHF IN [ANT, CATV, 75S(ohm)] or Cable Connector.
Disconnect the existing cable wire from the VCR's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your VCR's VHF IN.
Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
Connect the thin wire from the RF Switch (labeled Control Deck) to the back of the Super NES (labled RF Out).
On the back of the Super NES, set the 3/4 switch so that it matches the channel of the VCR. Note on Sharp TV/VCR Combo
After the system is connected to the VCR:
Insert the Game Pak firmly into the Control Deck.
Plug the controller(s) into the front of the Control Deck. Use the far left port for player one.
Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
Slide the Power Switch to the On position.
Turn your TV and VCR on. Set up your TV and VCR the same way you would to watch a movie on the VCR.
The game image should now be displayed on the TV screen. You are ready to play!
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck using the Stereo Audio/Video Cable.
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Nothing happening when hit power button....
If you are SURE you have hooked it up correctly, and it sounds like you have, be sure you have it plugged in a outlet that you know that works. You shiuld see the power light come on after turning it on. If it still doesnt work, you have to contact ebay or the person you bought it from for a return.If you need help dealing with Ebay please let me know, ive had to do it b4. Here are detailed instructions and the Service dept number for NES Connecting the NES Control Deck to your TV set There are two alternative methods of connecting the NES Control Deck to your TV set, depending on your type of TV: EITHER: (1) Using the Audio/Video Cable; OR: (2) Using the RF Switch and Converters. Make sure that you are not trying to use both the RF Switch and the Audio/ Video Cable: only one is required. First, compare your TV with the following illustrations (1), (2)(i) and (2) (ii) to determind which method you should use, (1) or (2). If you have a VCR connected to your TV, see below. --- (1) Using the Audio/Video Cable (Note! If your TV does not have direct audio/video connections, proceed directly to Method (2) "using the RF Switch and Converters".) Control Deck Back of TV Set (or VCR) -------------------------------------------------------------------------- Video-out jack Video-in jack --- Audio/video cable --- Audio-out jack Audio-in jack Note! Color coding of TV connections may differ from that of audio/video cable and Control Deck. Nintendo recommends against using a rear projection television with your NES as image retention on the screen may occur. To facilitate connection to video recorders, etc., many TVs have special audio/video input jacks. If your TV has such a jack, connect the audio/video cable supplied with the NES between the audio/video out jacks on the NES Control Deck and the audio/video in jacks on your TV set, and then flick the switch located on your TV that changes the TV from antenna reception to direct audio/video input. When you use the audio/video cable to connect the NES to your TV, there is no need to use the RF switch or converters, or to touch the antenna on the back of your TV. For more information on direct audio/video hookups to your TV, consult your TV Operation Manual. --- (2) Using the RF Switch and Converters (compatible with most TVs) (i) If your TV has TWO SCREWS FOR VHF antenna connection, connect the RF switch and NES as shown below. If your TV has a VHF cable connector, please see below. (Note: The existing antenna/cable to the TV should be first disconnected from the TV and then reconnected to the RF Switch. This will allow the signal from the antenna/cable to reach the TV when the NES is turned off.) Rear of Control Deck --- RF Switch -- 75/300 ohm converter -- VHF Screws --- (ii) If your TV has a VHF CABLE CONNECTOR connect the RF switch and NES as shown below. (Note: The existing antenna/cable to the TV should be first disconnected from the TV and then reconnected to the RF Switch. This will allow the signal from the antenna/cable to reach the TV when the NES is turned off.) Rear of Control Deck --- RF Switch --- VHF Cable Connector Note: if a VCR is already connected between the antenna and the VHF terminals on the back of your TV set, the RF Switch MUST be installed BETWEEN the VCR and the TV as shown below: (Refer to the illustrations above for your type of TV connection.) With this hook-up you are still able to record TV programs while using the NES. Antenna -- VHF in (From Antenna) VHF out (on VCR, to TV) -- RF Switch -- TV RF Switch -- Control Deck --- Connecting your NES Components. - Connecting the AC adapter to the control deck Insert the AC adapter power plug into the AC adapter jack on the back of the Control Deck. - Connecting the controllers to the control deck Both controllers are identical and may be connected to either controller socket. However, the controller connected to controller socket 1 becomes Controller 1, and the controller connected to controller socket 2 becomes Controller 2. The distinction is important when selecting and starting games, since only Controller 1 is used to select and start games. NOTE: Do not insert or remove controllers from control deck during gameplay as this may cause game malfunction. --- Operating your NES - To Start Play 1. Turn your television on to Channel 3. (Note: If Channel 3 is broadcasting in your area and interfering with the game, set the television and the switch on the back of the Control Deck to Channel 4.) 2. If your TV has an automatic fine tuning control (AFC), turn it off. (Use the manual fine tune dial to adjust the picture after inserting the game pak as described below.) 3. Make sure that the power switch on the Control Deck of off. Caution!! Always make sure that the power switch on the control deck is off before inserting or removing a game pak!! Always check the game pak edge connector for foreign material before inserting the game pak into the control deck!! 4. Open the Chamber Lid on the Control Deck. Insert a Game Pak into the Chamber (label facing up) and push it all the way in. Press down on the Game Pak until it locks into place and close the Chamber Lid. 5. Turn on the power switch of the NES Control Deck and push the reset button. Note: If the "reinsert" indicator light on the front of the Control Deck is flashing, it means that the game pak is not loaded correctly. In this case, turn off the Control Deck power switch and start over from step 4. Note: When the game pak is inserted properly, a colorful game display should appear on the TV screen. If it does not, or the picture is imperfect, turn the Control Deck power switch off and then on again, and press the reset button. 6. Use the Select button on Controller 1 to select the game you want to play, and start the game with the Start button on Controller 1. Note: If you experience any problems in operating your NES, please do not hesitate to call Nintendo's Consumer Service Department, toll free, at 1-800-422-2602.
How do you hook up the super nintindo console to the tv?
Original-Style Super NES RF to TV Hookup
hook_sns_rftotv.gif Installation Steps:
  1. Locate the TV's VHF IN [ANT, CATV, or 75(ohm)] or Cable Connector.
  2. Disconnect the existing cable wire from the TV's VHF IN.
  3. Connect the short, thick wire from the RF Switch (labeled ANT) to your TV's VHF IN.
  4. Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
  5. Connect the thin wire of the RF Switch (labeled Control Deck) to the back of the Super NES (labled RF Out).
  6. On the back of the Super NES, set the 3/4 switch so that it matches the channel of the TV.
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck to your TV or VCR using the Stereo Audio/Video Cable.
After the system is connected to the TV:
  1. Insert the Game Pak firmly into the Control Deck.
  2. Plug the controller(s) into the front of the Control Deck. Use the far left port for a one player game.
  3. Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
  4. Slide the Power Switch to the On position.
  5. Turn on the TV and set it to the appropriate channel (3 or 4.)
  6. The game image should now be displayed on the TV screen. You are ready to play!
I have the first nintendo nes and i dont have the rca's i have the one you hook through the cable and it comes on but i cant find the channel to put it on to play the game ! What am i doing wrong ?
Installation Steps:
1helpful
Ive just bought an nintendo off ebay. ive got the console itself the power cable and the tv ariel i switch it on and i can see the game is on but very badly barley like very fuzzy can someone help me...
Well it might be the rf switch that is causing the problem so buy a new rf switch and remember if only works on channel 4 or channel 3 then rf switch.
The screen is fuzzy - i'm wondering if it has something to do with the coaxial connection from the system into the TV. I have an LCD TV.
Well instead of using the rf switch you could use the av cable for NES instead or
the 3 in 1 rf switch then.
images?q=tbn:and9gcrbnoq7qlvo_fto5sm2x54uajxwba26o69iusfmp54v5znt00o8ehqopj8 images?q=tbn:and9gcracbkpnp2t4htfajea_1tmjifpnwacluvc7urvlramcabqhv8aurfvvq If you are using a digital tv instead of a CRT style tv use the av cable instead then.
1helpful
Bad picture with Sega Genesis model 1
Taking your problem in a whole new direction, why don't you try purchasing an 8 or 9-pin (depending on the type of Genesis you have) DIN RCA cable. This will improve picture and sound, and you won't have to worry about malfunctioning RF converters. Your problem sounds like the RF adapters are inadequate.
2helpful
Atari 2600 fuzzy screen
Hello, Are you using a newer flat panel or and older TV? IF you are using a newer TV the picture will never look very good. IF not, did you try working with the RF adapter? Check all connections. If all else fails try to get another RF adapter to see if that helps. I remember this being a bit problematic even when these were new. Wish I had a definite answer for you! Good Luck - Dr. Know
Audio problem with NES
try switching both the tv and the rf switch to ch.4, if that doesn't help make sure that there is nothing connected to the in port on the rf switch and try it again, also make sure the connector of the rf switch has a straight pin and not bent too badly, also make sure the pin does not look tarnished/corroded in any way, also check the connector at the end that connects to the nes, i would try changing the rf adapter before the console, if the power cord is in good shape everything else should be easy to find a replacement for. if you hae a snes try changing the rf adapters, or try using rca type cables, the out ports are on the side of the nes and most likely on the back or front of your tv.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
